Results 1 to 21 of 21
    Registered Users irish2themax's Avatar
    Nov 2008
    WV: Martinsburg
    Default "Clunking" sound on turns
    I've noticed that I'm getting a "clunking" sound in the front end on hard turns in either direction. Sounds like something heavy rolling around in in the frunk (which is empty). I'll have Cowtown check it out on the 13th.
    Any chance it could be associated with my sway bar? If so, is that normal?
    In order to find his equal, an Irishman is forced to talk to God. God looked down upon Ireland and said "Damn, I'm good!"
    2009 POW*MIA SE5
    Mar 2008
    Allegan, MI
    Could be, but it is more likely worn shock bushings.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Doru the Destroyer-Spyder Photo Investigator docdoru's Avatar
    May 2008
    Clearwater, FL
    2013 "Silver Dream" GG Taurus
    2008 "Silver Dream" Spyder RS
    Einstein's theory of drag racing: Time and Speed are Relative.
    Shut up and Race!
    Out of work Member RTGENE's Avatar
    Jan 2008
    LECANTO FLORIDA
    Default service
    I am taking mine into CowTown Monday and dropping it off.
    I have asked for the usual oil change maintenance at 15K-----I have also asked them to give me a pre-flight check for our 6K plus road trip.I trust that anything questionable will be dealt with. You can do the same request on the 13th
    Beyond happy SpyderLover
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by docdoru View Post
    Love the redish/orange accent! Too many twisties...!
    Nov 2008
    WV: Martinsburg
    Quote Originally Posted by NancysToy View Post
    Thanks...I'll have Cowtown make me well
    2009 POW*MIA SE5
    Nov 2008
    WV: Martinsburg
    Quote Originally Posted by Spydergene View Post
    I'm on their schedule for the 13th to get a thorough check-up and correct a few minor probs. Going to call them Monday to be sure they have bushings in stock just in case that's what it is
    2009 POW*MIA SE5
    Very Active Member Firefly's Avatar
    Feb 2009
    Ceresco, Michigan
    Quote Originally Posted by irish2themax View Post
    Mine did the same thing--- ended up needing to re-tighten the sway bar. It was the pressure against the trunk and the bar would move a bit and cause a 'clunking' against the trunk.
    Jack it up and tighten all the sway bar mounts. I did this and the noise went away instantly.
    You can probably hear the noise if you stand on your bike and rock it side to side which sitting still.
    Spyder #1 - 2008 GS SM5 Premier Edition #1977. RIP after 80,000 miles.
    Spyder #2 - 2012 RT SM5. Traded in after 24,000 miles.
    Spyder #3 - 2015 F3 SM6. Put 13,000 miles on and sold it.
    Spyder #4 - 2017 F3 SM6. Too good of a deal to pass up!
    Mar 2008
    Allegan, MI
    Can't replace the shock bushings, you must replace the entire shock. Check the sway bar mounts first, as Firefly said.
    -Scotty
    Aug 2007
    Greeneville, TN
    Energy Suspension Shock Bushings - SummitRacing.com
    Mar 2008
    Allegan, MI
    That'd be great, but I don't see any metric sizes specified. You'd have to take a chance on the Japanes car version, or make a sleeve to adapt the bolt to the US sizes. BTW, getting old bushings out of a factory shock is a bear! Not sure it would be worth the trouble...and certainly not if still on warranty.
    -Scotty
    Aug 2007
    Greeneville, TN
    I've done it before, replacing the OEM rubber (which are never any good - pretty much junk right out of the box) with a good polyurethane part. It takes a bit of effort but with some WD-40 the old ones will punch out.
    Once I get the specs. on the shock eye / bolt, I should be able to find a perfect replacement. There are all kinds of them out there in metric sizes. The 2 piece are easier to put in but I prefer the hour glass style. I think I'll get RED!
    It is amazing what it does for the suspension as long as the shocks are still working well.
    Then I can give Doc a run for his money in the twisties! YEAH!
    Of course a set of Elka's would also solve the bushing problem!
    Feb 2009
    Ceresco, Michigan
    Let us know what you come up with for the right sizing. I can pop out the old ones from my original shocks if that will help....
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by Firefly View Post
    I have been wanting to do mine anyway. I just don't get around to things like I used to.
    Old bushings aren't going to give me the OD spec that I need (unless they were in good shape). Bolt size will be no problem.
    I think Lamont has a set of RS shocks laying around. He's got a set of EVERYTHING laying around his garage!
    And I'm not against someone else doing the leg work either (as long as I get the credit! )
    Registered Users SpyderWolf's Avatar
    Oct 2009
    Martin, SC
    If you need to replace the shocks then you may as well put the RT ones on there, as Lamont and others have said they give you a much better ride than the standard GS ones.
    Very Happy Spyder Ryder!
    Click here to see My Spyder Mods
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by SpyderWolf View Post
    I don't know yet if my shocks are bad. On the other hand a set of RT shocks would be a good move. Either would benefit from a good set of bushings.
    Nov 2008
    WV: Martinsburg
    Cowtown fixed the problem...sway bars installed on the wrong side of the chassis. Simple fix
    2009 POW*MIA SE5
    Oct 2009
    Martin, SC
    Glad to hear it was nothing too serious. Was this the performance sway bar that you installed yourself, or was something done wrong with the stock set up?
    Nov 2008
    WV: Martinsburg
    Was aftermarket but installed by my dealer
    2009 POW*MIA SE5
    Oct 2009
    Martin, SC
    That is a shame, as it doesn't seem like it would be that difficult of an installation.
    Ride Forrest Ride!
    Jul 2008
    Kissimmee, Florida
    Its the Blarney stone.
