RT-S PE#0391
Replace Horn on the Spyder RT?
Hi ... RT PE 391 is a great machine with only a couple of 'I wish's.' One of them is that I wish it didn't have such an anemic horn. It just sort of goes "hoot" with not much volume. Has anyone considered replacing theirs' and with what?
Paul
Mod Maniac
Paul
Don't see why this wouldn't work on an RT... mount location may be different but still...:
http://www.spyderlovers.com/forums/s...7&postcount=81
ata = allergic to asphalt
My mods: https://www.spyderlovers.com/forums/...ead.php?t=5753
There are two kinds of people: (1) those who can read, reason and apply the experiences of others; and (2) those who just have to pee on the electric fence. ataDude, 2009
My Spyder:
RT-S PE#0391
Yeesh ... electrical probs? Bus system? Air horn?
Umm ...perhaps just a better electrical solution that replaces the stock horn.
Mod Maniac
My Spyder:
RT-S PE#0391
Horn Anemia
You're most probably right, AtaDude ... I'm gonna need to get smart on this, to include knowing where my RT horn is at. As a new owner, and not a bike mech, I'm a bit reserved to start digging around. I've already had the 'thrill' of pushing the rubber grommets through the faring mounts when checking oil.
"Stupid is as Stupid does"
Don't Drink and Drive or Ryde!
Each Day is a Gift
Mod Maniac
Originally Posted by YPILOT
Thanks ataDude for the layout. I've had one of these horns for awhile. Looks pretty straight forward and easy to follow. What gauge wire did you use for the horn install? Regards Dennis
14 gauge minimum for the power. Use the current horn wire for the relay trigger.
My Spyder:
RT-S PE#0803
Stebel in place of stock horn
When we had the front trunk off I replaced the stock horn with the Stebel. It required opening the hole for the horn to protrude some but it wasn't bad and I strenghtened the horn bracket and added the relay in the same area. as a result I ran a separate ground and positive with 14g wire from from the battery and it works great.
Taking the front trunk out wasn't bad and getting the panels around the horn out was easy. See a couple of photos below.
Lonnie
"May all your tomorrows, and miles, be better than all your yesterdays." LH
