Results 1 to 17 of 17
Thread: DPS issue
    May 2009
    Alexandria, VA
    Default DPS issue
    So, the good news and the bad news:
    1) I got my Spyder RT-S (limited edition). I'd ordered an audio and convenience, but the shop kindly upgraded me to the ltd edition at no additional cost
    2) The bad news. About 100 miles on the odometer the bike threw a code while running at about 50 mph. The warning 'light' illuminated and the RCC flashed an issue with the DPS. The engine light also illuminated. I think I also lost power, but I'm not really sure about that. In any event, few seconds later, power was fine.
    I took the bike home (I couldn't feel any change to the steering), let it sit, and started it up, then drove it 15-20 miles. No recurrence of the code. I'm sure it's still stored in the computer, but I don't know how to get the codes on an RT.
    Ben
    Motorbike Professor
    Mar 2008
    Allegan, MI
    The fault code retrieval procedure is listed on another thread, but it will only retrieve active codes. To retrieve the "occured" codes you will have to take it to a dealer and hook it up to BUDS, which you should do anyway, with difficulties on a brand new ride.
    Based on your problem, though, make sure your battery is fully charged, and check that the relays and fuses are all pressed firmly in place.
    Aug 2007
    Springfield, MO
    Chances are it was a low battery and a real DPS problem.
    Registered User groundeffect's Avatar
    Dec 2009
    Newfoundland, Canada
    There is a recall, as I understand it, on the RT (RT-S???) regarding a possible loss of power as a result of a wiring harness being tightly packed under the ignition section. It may or may not affect you, but may want to check with your dealer that it was verified your RT was in the recall range and checked, or not affected.
    Hope that helps and good luck. Please keep us updated on what you find out. As Scotty mentioned, having the code would be useful, but your dealer, if you go in to them ( a good idea, ihmo ) will get it from BUDS computer connection.
    Cheers and good luck.
    May 2009
    Alexandria, VA
    Thanks all - took it for another ride, still no problems. But, I've had issues with intermittent codes on other bikes before so I guess I'll wait and see - though I'll definitely bring it up with the dealer.
    Quote Originally Posted by groundeffect View Post
    RT-S SE PE#0192
    Sep 2007
    Topeka, KS
    Bhawksworth,
    Did it go into "limp mode"? Limp mode won't let the rpm go above 3500 rpm, that's equal to about 50 mph on my RT. If it did go into limp mode I would suspect the same problem I had (see the thread on limp mode). I got my RT back from the dealer Saturday. It was in for service and the limp mode fault. After much testing by the tech at the direction of BRP the "Yaw Sensor" was replaced. Luckily the tech experienced the same fault on a test ride after they had performed all of the tests BRP wanted. BRP then authorized the replacement of the Sensor. They had been reluctant to replace it because they had never had any problems with the yaw sensor (per BRP!). Much credit goes to the tech at Reno's in KC. They had actually ordered the sensor before BRP ok'ed it. If they hadn't I still would be waiting on my trike. I was treated very well by Reno's, I'd reccommend them to anyone, their Spyder tech had just completed another BRP school and appears to be very knowledgeable about them.
    Dwight
    May 2008
    Clearwater, FL
    Quote Originally Posted by Dwight View Post
    Limp mode won't let the rpm go above 3500 rpm, that's equal to about 50 mph on my RT. Dwight
    Max 4,500 rpm in any gear and/or 45 mph.
    May 2008
    Clearwater, FL
    They had been reluctant to replace it because they had never had any problems with the yaw sensor (per BRP!). Dwight
    I know at least 8 Spyders with the YAW sensor replaced.
    May 2009
    Alexandria, VA
    I'm not sure. It stumbled, seemed to lose power. I had to pull across a lane to the shoulder, as I was afraid I was going to come to a stop in the middle of the highway (a big thank you to the pickup that ran up my ass while I was trying to do this), but by the time I got there the power had returned. So maybe it was briefly in iimp home mode, or maybe it was some other issue. Curiously I was not turning when this happened. Just straight line driving.
    Bhawksworth,
    Dwight
    May 2009
    Alexandria, VA
    I added another 130 miles with no recurrence of the problem. I talked to the tech at my local shop. He said (accurately) that there have been lots of problems with DPS issues with Spyders. He put them in two categories: 1) warning lights that can be corrected by a software update; and 2) genuine mechanical problems.
    He suggested I continue to ride through my 600 mile service and see if it recurs. I feel pretty comfortable with this because when the issue arose, I didn't experience an actual steering problem. I would, however, prefer not to lose power in the middle lane of a highway. Maybe just me, though.
    Apparently it costs BRP $1500 for a new DPS. And he says that they are insistent on immediately receiving the faulty DPS motor. I guess that's a good thing. $1500 must eat into profit, so I presume they are fairly enthusiastic about solving these types of issues.
    Very Active Member Firefly's Avatar
    Feb 2009
    Ceresco, Michigan
    Quote Originally Posted by BHawksworth View Post
    The manufacturer of the DPS units (Kongsberg ) is covering them--- so BRP isn't footing the entire bill. Besides, they should have insurance in place to cover such incidents.
    Spyder #1 - 2008 GS SM5 Premier Edition #1977. RIP after 80,000 miles.
    Spyder #2 - 2012 RT SM5. Traded in after 24,000 miles.
    Spyder #3 - 2015 F3 SM6. Put 13,000 miles on and sold it.
    Spyder #4 - 2017 F3 SM6. Too good of a deal to pass up!
    May 2009
    Alexandria, VA
    So... my RT-S threw DPS/engine/VSS codes again yesterday, and went into limp home mode. Drove back at <45 mph for five miles. 238 miles on the odometer.
    May 2009
    Alexandria, VA
    The dealer says that the problem was a bad steering sensor - so I guess I'll wait and see how she operates on the road.
    May 2009
    Alexandria, VA
    Got my RT-S back today. Drove about twenty miles, got on an off-ramp, and suddenley felt the bike tug to the left, pulling me toward the outside of the corner for a moment. Not uncontrollable - it only happened briefly, like the VSS had triggered the left front brake. Then on came the VSS, DPS, and engine lights. Sigh. Back to the dealer, with less than 300 miles. Very disappointing.
    Aug 2007
    Springfield, MO
    At this point I would contact Carlo
    http://www.spyderlovers.com/forums/s...ad.php?t=10017
    If you would like me to blaze the trail for you let me know.
    Jul 2009
    Beaufort SC
    Quote Originally Posted by Lamonster View Post
    Lamont is good at blazing trails.
    Thanks for helping me out Lamont!
    May 2009
    Alexandria, VA
    I will, if he hasn't seen this exchange already. He had been kind enough to call me previously, and to put in a word for me at the dealer (who have been trying to be helpful, too), which I much appreciated. Of course, that was before this latest event.
