Results 1 to 19 of 19
    May 2015
    Independence, MO
    Default Phone Holder / Wiring
    I want to get a phone holder for the handlebars to run my GPS on my iPhone on long trips. Any suggestion on holder and moving the wiring from the back truck to the handle bars. Note - I am not very knowledgeable on wiring so if it is not super easy I will probably have to farm out the job.
    Linden, CA
    Default I have phone holders
    Check out the holders at
    motorcycledave.com
    Cycle Gear. com has the 12 volt plug setup
    on sale It has the wire ane fuse all
    set up for motorcycles I think
    it was $12.95 easy hook up
    Jul 2013
    Vestaburg Michigan
    Pro Grip makes holder for specific phones , some have charging plugs built in.Check ther Web site. You will need to run power up front if you want to keep phone charged. This is another option. Ther are many threads on the subject, you can do a search.
    Mar 2015
    Brockport, NY
    Default Ram mount and wire from trunk
    I used the ram mount handle bar mount for my iPhone with gps. I ran a 10' usb iPhone cable from trunk to handlebars. Was pretty easy after removing the right side Tupperware, which you can watch tutorial on YouTube. It works great and required no hard wiring. You will need to drill small hole into rear trunk to feed wire through. Pm for pics if you like.
    2014 RT-S Pearl White
    Active Member markyodo's Avatar
    Columbus, OH USA
    Quote Originally Posted by mross5150 View Post
    RAM Mount X-Grip for your phone. USB charger for power. Bluetooth for audio connection. Keep the existing wiring for your iPod.
    Our Scenic Life - Spyder Videos
    https://www.youtube.com/channel/OurScenicLife
    Ask me about my Spyder.
    2014 Black Can-Am Spyder RT
    May 2015
    Upstate NY
    Default Ram X-grip
    I purchased my phone grip at SpyderQuest. Extremely easy to install/use:
    http://www.providence-spyder-accessories.com/
    Check out their power solutions. If you call them, they are very helpful.
    Lots of other solutions in the forum. Pick what makes sense and works for you.
    Mar 2015
    Brockport, NY
    Default Ram mount on handlebar
    I have the ram mount on handle bar and ran a usb cable from trunk to iPhone. Very simple and works well for me.
    Apr 2012
    Florida
    Check out JT here on our forums. I have a dual USB in the dash in place of the stock gauges, from JT. Also a clock the is readable on the other side. You will then have digital gauges in your screen. Also picked up a collar with ram ball and spyder grip and drink holder from Lamont. Tom
    2020 Petrol Blue Metallic RTL
    Jun 2015
    Midland, TX
    I purchased the Carchet Dual USB Power Port and wire harness for one of our site sponsers, JT. I installed the USB in the blank switch in the switch panel.
    Active Member FINFAN3DP's Avatar
    Jun 2018
    HAYMARKET,VA
    Quote Originally Posted by KJWEB View Post
    How hard was it to wire this? I'm very worried about hacking into wires.
    2020 Can Am Spyder RT Limited "The Comet #2"
    Baja Ron Sway Bar
    Passenger Armrests From Can Am
    Wolo Big Bad Max Airhorn
    Lamonster Top Cuff W/Ram Ball
    Lamonster Power Plate
    Tackform Phone Mount
    Key Cover from Ebay
    Lamonster Mirror Locks
    Ultragard Cover from Lamonster
    Top Grills from Spyderpops
    Garage Door Opener from Spyderpops
    3.5mm Extension from Amazon
    Lamonster USB Cable Holder & Cable
    Foam Grips from Spyderpops
    Tricled Strobe Brake Light module
    Tricled Bag Lights (replace reflectors)
    Tricled Turn/Brake/Run Signals Rear
    Tricled Floorboard Lights
    Tricled Sequential Run/Turn Fender Lights
    Tricled A-Frame Run/Turn Lights
    Tricled LED American Flag Mount & Flag
    Showchrome American Flag
    2020 RT Limited , Says Chalk White, but in person it is much more gray
    Nov 2018
    Glendale Springs, NC
    I installed a USB charging port using this video. I got the port off of Amazon for about 17 dollars and it works great. http://www.canamspyderaccessories.co...l-usb-charger/
    2014 RT Limited , Pearl White
    Jun 2018
    HAYMARKET,VA
    Quote Originally Posted by CarolinaRT View Post
    I was just watching the video on this site... Not so sure I like the idea of splicing into the wires, worried about moisture.?? What do you think about it?
    Baja Ron Sway Bar
    Key Cover from Ebay
    Jun 2018
    HAYMARKET,VA
    Quote Originally Posted by Tango View Post
    Thinking LAmontsters phone mount is the way i'm gonna go, but I need to get a tether for it.
    Baja Ron Sway Bar
    Key Cover from Ebay
    May 2013
    Stanton, ca
    FYI, if you have a new 2015 or up, the power wire is no longer there. Older Spyders had 4 wires to the gauges and one was a 12V power wired for the gauge light bulb. Perfect for tapping into. This video shows an older pre 2015 Spyder.
    This is now gone as the newer gauges have a LED instead of a 12V bulb and are only 3 wires. Do not tap into those as they go through the cluster and won't handle a lot of AMP draw. You risk blowing your cluster.
    Bob
    Active Member INfox's Avatar
    Jun 2017
    TX
    Thank you Bob so much for the warning. I wanted to order this Dual USB plug for my 2017 RT LTD.
    What would you suggest for my Spyder model to go with? I would really like to have two USB plugs in my handlebar area instead of the back. I am planning on using GoPro Hero 5 and Galaxy S8 in addition to the Garmin GPS.
    2017 RT Limited Asphalt Grey with Lamonster RT Spyder Cuff; Lamonster FBB Highway Bracket; Kuryakyn 7597 ISO Trident Pegs; RoadSport Big Mudder Extreme, Magic mirrors, Airhawk R, plastidipped Frunk, Ram Mount Universal X-Grip IV Large, FZ-1 fuze block, Dual USB charger, BajaRon Sway Bar, Black Powder Coated RT Dash Mount Bracket
    Active Member Tatonka's Avatar
    Jan 2018
    North Carolina
    Check out Lamonster's power ports.....easy to wire and incorporate with ram mounts.
    Jun 2017
    TX
    Tatonka, I did check them all and I have to say I would prefer to have a clean install without the extra wires or additional mounts obstructing the neatness of my 2017 LTD. I want to leave the nuvi 590 GPS where it is as well.
    I even emailed them asking for parts for the Dual USB rocker clean internal wire install and I was referred to check with SpyderLovers. I am so frustrated, I even posted a separate thread with links to all the parts I was thinking I could or would use and was pointed to the La Pierre great install video which shows the older model.
    SpyderLovers is a great forum and I am very thankful for all the ideas and advices. I spent many hours reading this forum and researching the web without knowing exactly how to connect the Dual USB rocker to have a running engine only power, not continuous.
    I did connect Battery Tender to the battery terminals already and I don’t think it would be a good idea to add additional wires for the USB. Maybe I need to spend extra money for the FZ-1 Fusebox or possibly Rowe PDM60 (which needs some computer setup that I am not sure I will be able to do as I am not an electrician). Do these come with wiring connection instructions?
    I did purchase the 2016-2017 BRP Repair Manual already – it is complicated with 1579 pages. I will split the Spyder RT 2016 Electrical System page and print it for an easier view to hopefully follow the diagram.
    One thing I don’t seem to find out is what is the best wire connection solution for the 2017 RT LTD models with a detailed information. I will be running the Samsung S8 and GoPro 5 continuously for 5-6 hours with nuvi 590 sometimes as well. Not being an electrician, I don’t want to blow the switch cluster running all these peripherals.
    Aug 2018
    Thousand Islands
    I used Quadlock on my RS and im in the middle of setting it up on my F3 using lamonster bar clamp and quadlock mounts, wireless charging and factory clean look.
    Aug 2018
    Thousand Islands
