RT-S PE#0803
Can-Am Zumo 660
Anyone know if you can add the traffic receiver to the Can-Am set up on for the Zumo?
Thanks in advance. Lonnie
SpyderLovers Founder
FM traffic compatible: yes
Not sure if that's what you're looking for but here's the specs.
https://buy.garmin.com/shop/shop.do?...15000#specsTab
RT-S PE#0803
Traffic Receiver
Thanks Lamonster. I checked with Garmin also and they said that the 660s were built with the traffic receiver and unless BRP changed the unit when they built their version it should have it with a 3-month free subscription.
Have fun Sypder Lovers.
The 660 is the same, all they did is tie it into the sound system.
RT-S PE#0412
You have to buy the trafiic receiver accessory.
https://buy.garmin.com/shop/shop.do?...afficReceivers Edit: link doesn't take you to the receivers. Click on Accessories and then Traffic Receivers
They have MSN and Navtek traffic options. Also see from Garmin:
Notice: MSN Direct service will be available only until January 1, 2012.
2013 ST-S SE Pure Magnesium
