Results 1 to 11 of 11
    Oct 2024
    Birdwood, South Australia
    Default Should there be a bolt thru these Empty holes?
    Hi All.
    On my new 2023 RT Ltd, I crawled underneath by the back wheel and above the muffler I saw a bracket with holes that line up with a panel. I checked the other side and there was a similar bracket with empty holes.
    Should there be a bolt through these holes?
    Last edited by Peter Aawen; 10-30-2024 at 12:14 AM. Reason: Expanded title to briefly ask the question... ;-)
    Dec 2013
    Maybe not a bolt, but they definitely look like they should at least have push pins in them...
    Have you read that last PM reply I just sent you, mentioning things very much like this from that dealer??
    I wouldn't be at all surprised if there's more things like that which either weren't done at all during assembly; or they weren't done correctly/properly!
    That reminds me, we haven't had a local working bee/maintenance day here in South Oz recently, maybe it's time for another?? I'll look into it.
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Aug 2016
    South Wales UK
    I recently replaced the left side side box opening cable on my 2021 S2S. There was definitely a bolt in that position on my bike. If I remember it was a 6mmx20mm or 25mm bolt with a largish washer top and bottom with nyloc nut. It locates the large black side panel, a metal bracket on the frame and the black trim panel that goes around the side box and opening/lock panel. Hope that helps.
    Alan.
    Active Member BamaJohn's Avatar
    Feb 2015
    Talladega County, Alabama
    yes...agree with Flier Tuck. One side of my 2020RT was missing the bolt, so replaced it. It helps hold the side case in position.
    John B.
    Current ride: 2020 Spyder RT-s Petrol Metallic Blue dark with OEM top case
    Active Member Albec's Avatar
    May 2024
    Northern Illinois
    You made me go out to the garage and lay on the floor! lol
    My F3 does indeed have bolts at those locations.
    Care to name your dealer?
    2023 F3 LTD Special Series.
    2023 F3 Ltd SS , Mineral Blue / Carbon Black
    Feb 2012
    Spring City,Utah
    Since he is in Australia, I doubt any of us will ever run into that dealer, and judging by Peter's comment in #2, the quality of their work is already known down there.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Sep 2020
    Middletown, NJ
    Those bolts are the lower-back fixings for the big black panels. Whoever had the panels off last didn't replace the bolts.
    2020 RT base , Chalk White
    Aug 2019
    Stoughton, WI
    Yup ... Missing nut/bolt. Should look like this...
    2022 RT Sea To Sky
    Aug 2018
    Piperton, TN
    I know mine were loose from driving and I had to tighten them up. Maybe they were there and fell off. But for sure, you should have a fastener there.
    Jun 2016
    Harrington, Australia
    Quote Originally Posted by RayBJ View Post
    It’s a new 2023, Ray. I would imagine that this is a dealer assembly failure. Unfortunately, Australia has its fair number of “less than exemplary” Spyder mechanics, just like the US has
    Pere
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Ikon (Aussie) shocks all round, with sag adjusted for extra 3/8” clearance up front
    Kenda Kanine rear.
    Oct 2024
    Thanks for the info, I will get some bolts from my workshop and fit them properly. I have a large supply of bits as my previous bikes were Royal Enfields, and the saying is 'making riders into mechanics since 1901'.
