Results 1 to 4 of 4
    Sep 2024
    New York
    Default Any Advice/instr on Reinstalling RT Ltd Rear Fender Extension?
    Trying to find some advice/instructions on reinstalling the rear fender extension on a '23 RT Limited. Screwed up and got stuck in some sand, and when the rear wheel sunk, it ripped the extension off. I got a new one but can't find instructions for it. I'm sure I'm just missing something stupid, but I can't get it to hold on those plastic clips. Any help would be much appreciated!
    Last edited by Peter Aawen; 10-02-2024 at 03:45 PM. Reason: Expanded title to briefly ask the question... ;-)
    Feb 2022
    north dakota
    I have the same problem. need a new mudflap but the factory one is way over priced. I would also appreciate any help
    Nov 2015
    Chardon, OH
    Quote Originally Posted by Jeffjas View Post
    Trying to find some advice/instructions on reinstalling the rear fender extension on a 23 RT Limited. Screwed up and got stuck in some sand, and when the rear wheel sunk, it ripped the extension off. I got a new one but can't find instructions for it. I'm sure I'm just missing something stupid, but can't get it to hold on those plastic clips. Any help would be much appreciated!
    Did you remove the rear panel? Because I can see that it would be quite the b##ch to clip those 4 clips with the panel on and the rear tire in the way. Plus, don't forget the two plastic screws on each side attaching it to the panel. Are there any broken off pieces from the old one interfering?
    But, these instructions for the BRP Trailer Hitch include installing a new fender extension that comes with that kit. Done with the rear panel removed. Maybe they’ll be some help.
    https://drive.google.com/file/d/13qA...ew?usp=sharing
    Doug
    ”Freedom is not a loophole”
    F4 Customs SWCV, Ultimate, Lidlox, Adjustable Side Vents, Leather Like Grips, SS Grills, Centramatic, Garmin XT2, BajaRon Original Sway Bar w/ Lamonster links, RLS CD w/ baffle, P238
    Sep 2024
    New York
    Thanks. I tried it with the rear panel on. I could line up the holes for the two screws, but yeah, it was impossible to get those four pins placed. Those directions were helpful, and they showed me there’s a lot to take off to get the extender back on correctly. The Spyder is due to have an inspection next month, so I’ll probably just overpay the dealer to put it back on.
