Results 1 to 17 of 17
    Mar 2015
    Tacoma WA.
    Spyder Are warped discs a common problem with Spyder Front Brakes?
    Just replaced the front discs and pads on my 2017 F3-S. It has 25k miles, and the old brakes were shuddering when stopping. Apparently, the discs were warped. Anyway, is this a common problem with Spyders?
    Last edited by Peter Aawen; 09-29-2024 at 02:43 AM. Reason: Expanded title to briefly ask the question... ;-)
    2017 F3-S Daytona , Yellow and black
    Very Active Member BajaRon's Avatar
    Aug 2007
    Greeneville, TN
    For some reason, it seems more common on the F3 than any other model. This has always baffled me because the RT is a much heavier machine. I can only attribute it to more aggressive riding. But this is nothing more than a guess. I highly recommend replacing the front rotors with EBC units. They stop better and are much more warp resistant than the OEM rotors.
    BajaRons@BajaRons.com
    423-609-7588
    Sep 2020
    Middletown, NJ
    I replaced a warped front rotor on my 2020 RT with EBC rotors from BajaRon at ~ 15000 miles. At 37k and all good.
    2020 RT base , Chalk White
    Very Active Member CloverHillCrawler's Avatar
    Mar 2021
    Maryland
    Still have the original OEM rotors at 34K, no issues. But since I drive with more spirit, I usually change the pads every spring needed or not.
    I also use engine braking whenever possible, so that has saved me wear on the rotors.
    I have to correct myself - the rear disc was replaced when I was rear ended.
    2020 F3 SE6
    Safety and Lighting: LED Headlight upgrade, IPS LED Fog lights, Show Chrome LED Fender Signals, LED Signature Light, Tric LED Afterburnerz, MotoHorn 2.0
    Suspension: Wilbers Front and Rear Shocks, BajaRon Sway Bar, Vredestein Quatrac Front and Rear Tires
    Comfort: Blue Ridge Windshield, Corbin Dual Touring Saddle, Ultimate Floorboards, OEM Passenger Backrest with Rear Shelf, OEM Passenger Floorboards Modified with High Risers from Pierre
    Tackform Center Mount Phone Holder w/ rapid charging USB-C.
    2020 F3 , Black
    Mar 2015
    Tacoma WA.
    I'm glad you recommended the EBC disks and pads, because that's what I just replaced the OEM parts with. You can get Chinese replacement disks for half the cost... but you'll get what you pay for.
    Quote Originally Posted by CloverHillCrawler View Post
    Just curious, what happened when you were rear-ended? Did the trike suffer a lot of damage?
    Terry
    Mar 2021
    Maryland
    Quote Originally Posted by TerryTheSpyderRyder View Post
    Terry
    Stopped at a light on Route 13 in Delaware on my way to Bike fest in OC last Sept. when I was rear ended by a Honda and ejected out into the intersection.
    I had my gear on and got lucky and walked away with some major bruises that lasted a couple of months. My Spyder wasn't so lucky, the whole swingarm assembly had to be replaced. It was a little under $7k to repair it, covered by Progressive.
    2020 F3 SE6
    2020 F3 , Black
    Mar 2013
    Clarksville TN
    My experience with high performance automobiles taught me that most of the pulsations from "warped" rotors were actually due to uneven deposits on the rotors rather than a warped rotor. Of course, replacing rotors/pads "cured" that issue, too.
    2024 F3T (wife’s)
    2014 Indian Vintage
    2022 Lexus LC500
    1966 LS1 Corvette restomod
    1956 Corvette survivor (wife's)
    1941 Chevy hotrod truck
    2024 Corvette ERAY
    Very Active Member racoon's Avatar
    Feb 2024
    Tennesse
    Quote Originally Posted by petegtsv10 View Post
    I haven't turned many wrenches in the past couple of decades, so please excuse the following question:
    Do repair shops still "turn" brake rotors?
    Feb 2022
    very southern tip of Texas
    ‘17 F3-S, w/ just under 12K miles. Noticed a shudder on stopping a couple weeks ago. Pulled front wheels to check pads. Found inner pad on RH side was worn at an angle, more wear on bottom, less on top. But seemed as though all pistons were free and moving. LH side was fine. Will probably go ahead and order new rotors and pads when I get home from Green Country Spyder Jamboree tomorrow.
    White 2015 F3-S SE6 - “Gypsy” (hers)
    Yellow 2017 F3-S Daytona 500 SM6 (his)
    Mar 2015
    Tacoma WA.
    Some serious damage there, I'm almost surprised it wasn't totaled.
    Terry
    Mar 2015
    Tacoma WA.
    Quote Originally Posted by BCNewell View Post
    Your Spyder is exactly like mine except, did you paint the front wheels with yellow? Mine are all black.
    Terry
    Dec 2016
    Easley, SC
    I have a 2023 Sea2Sky and I had to replace the pads at 9000 miles. About 500 miles later when braking moderately hard shuddering started happening. I replaced the rotors also. Also, when I replaced the pads, one was almost worn down to the metal.
    Mar 2021
    Maryland
    Terry
    It was the second time something major happened to it, 3 months right after I bought it I was run off the road by a cage and ejected into a curb. I had a bruise that went from the back of my neck to my right knee for almost 6 months and my right hip was still swollen almost a year later.
    That time a reframe was needed and that cost a little under 12K also covered by progressive.
    2020 F3 SE6
    2020 F3 , Black
    Feb 2022
    Terry
    This: https://www.slingmods.com/can-am-spy...e00PZS1w5YZjQV
    Northern Kalifornia
    Quote Originally Posted by racoon View Post
    I've had my car's rotors turned but I don't believe there is enough material on spyder rotors to turn them safely. Better off to install new ones on a spyder. JMHO
    Aug 2007
    Greeneville, TN
    You can turn most vented automotive rotors. But single disks like those a motorcycle uses are not designed to be turned for the reason you point out. You can use Emery paper on them to remove embedded brake material. But if you put them on a turning lathe and take off enough material to correct warpage, there won't be sufficient rotor left to be serviceable.
    Most automotive shops no longer turn rotors because replacements have become pretty inexpensive and the time and labor to turn a rotor is usually no longer worth it. This is the reason that most mechanics have become part replacers instead of part fixers.
    423-609-7588
    Northern Kalifornia
    Yep, when I worked in my dad's shop, I honed and rebuilt wheel brake cylinders - I hated that job. Do they even have brake cylinders on cars anymore? I think everything is a caliper like our Spyders? We are living now in a throwaway society. What's next, teleportation? LOL
