This is the Hydraulic lift system manufactured by Amerideck in 2014 that allows you to lift your Spyder into the back of your pickup truck with the push of a button.
I also found this super useful for lifting anything up to 2500 lbs. into the back of my truck and would be great if you're a contractor.
Features:
generic - bolts into the back of any short 6.5' bed pickup truck by drilling two holes, or use the custom welded bed bolt brackets, for the 2000 F250 Ford.
includes the 18" pieces removed to fit back in the long bed if you want to weld them in.
Easy disconnect pins so you can leave the deck behind when not in use.
lots of welded in tie down points around the deck.
1/8" diamond plate steel surface.
This is the "Spyder deck" so it has the Spyder front wheel stops built in, but the hydraulics also accepts a dump box and the other style decks like the stake side deck.
The deck weighs 600 lbs. and the lifter weighs 400 lbs. so you really need a 1-ton truck, and it does not interfere with a trailer; we towed a trailer many times.
Asking $2500
Regardless of whether you're a Seller or a Buyer, please don't forget to read and follow the directions in the READ FIRST! Sticky at the top of the section, also linked below:
