Results 1 to 10 of 10
    Aug 2012
    Central Ohio
    Default Where is the Height sensor arm located?
    Had the Suspension Fault code come up yesterday and I can tell something is wrong. Been reading on here about a height sensor arm maybe coming loose. Do you take the passenger seat off and take an access cover off to check it or is it something that is visible from under?
    Mar 2017
    Salisbury,NC
    You didn't mention what model your talking about. Have to lay down on floor and look at swingarm. The linkage bolts up to swing arm. That is first place to look at, report back and we go from there for next problem to fix
    Aug 2012
    Central Ohio
    Quote Originally Posted by Woodaddict View Post
    Sorry. 2020 RTL
    Active Member NorwegianRT's Avatar
    Apr 2022
    Southern Norway
    Quote Originally Posted by Kingz View Post
    On my 2012 RTS the arm in mention ( I hope this is what you have in mind) is located here by the arrow.
    No worries, all my panels was off for another job, this can be inspected by just getting down there and look.
    Brgds Martin
    First Spyder: RS 2008 Yellow&Black - Current: 2012 Spyder RTS Magnesium, bought new from dealer in 2015.
    Jun 2016
    Harrington, Australia
    Quote Originally Posted by NorwegianRT View Post
    Yep, that’s about where it is on the ‘20 RT, Martin
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Russell Daylong seat 2 taller than stock (in Sunbrella for Aussie heat & water resistance)
    Goodyear Duragrip 165/60 fronts (18psi) - provides extra 1/2 ground clearance.
    Kenda Kanine rear.
    Apr 2019
    Clinton, MS
    If the arm is in place there is a schrader valve located under the seat where you can add air to the air bag. Check the air pressure. If its below 30 you may be bottoming out. if over 75 or so it may feel like it wants to launch you off the seat everytime you it a bump. You don't say what model you have but it could be a blown fuse for the air compressor, bad compressor, leaking tubing or a hole in the air bag if it's not the arm.
    2019 RTL Phoenix Orange
    Aug 2012
    Central Ohio
    It’s a 2020 RTL. Thanks for the replies. I think this is it and it looks fine. My next question was going to be how much air should be in the bag but sounds like I’ll pump it up to 30 lbs tomorrow. The compressor is working by the way. I can’t figure out how to add a photo.
    Dec 2013
    If you've got a height sensor that's working as part of the Suspension Height setting, then just as long as there's SOME air in the airbag (it needs about 10psi minimum), you don't need to and really shouldn't worry about 'how much' air/air pressure is in there, just that there's SOME!
    Quite simply, regardless of how much air you put in &/or might want to have in it, the moment you start to ride, the automatic system will adjust whatever pressure is in there to meet & maintain its specified/hard-coded preset ride height!! So if you add more air than it wants/needs to do that, it'll very quickly be bled out! Similarly, if you lower the pressure to something you think works best for you/your riding comfort - I'm sorry, but tough, cos as soon as you start riding, the system will add air to return the bag to a pressure that'll achieve its preset ride height level!
    If you have access to BUDS/BUDS-II, you might be able to go thru the process of changing the preset ride height to something you prefer, but otherwise, you're wasting your time doing anything apart from checking that it's still got some air in it and that it's not leaking down overnight/to nothing while you ride; &/or ensuring that none of those other things Ed mentioned aren't causing you issues!
    Just Sayin'
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Sep 2017
    Durham,Maine
    If in fact your bikes throwing a code, you may want to just take it into the shop and have them put it on the computer and make sure that sensor that you were looking for is in fact working the way it should, and that the systems not leaking down. You will burn your pump up then you'll ether have a big bill to change your pump or be back to us asking how to go to a manual fill!! Good luck!!
    2012 RTL , Pearl
    Aug 2012
    Central Ohio
    I will take it in but I’ve had bad experiences and heard so many horror stories about dealers that it scares me. In the meantime- Put some air in last night and took a ride and no suspension fault. It did lose some air overnight but wasn’t flat.
