RT-S PE#0256 SyderLovers Sponsor
RT Highway Brackets Done!
When you take delivery of your new RT, you will be already able to order your highway brackets !!! The protos are fit up and lookin good.
Is that RT a SM? If so where can I get the pegs? Some close ups please.
Yes, It is an SM. You can get these from kewlmetal. I can get you some close up pics real soon. Got it all tore apart at the moment.
Matt
Thanks Matt. I really missed the pegs so will be ordering tonight.
Jack
Look great! Will send you an email re Sat.
Jack
Wow! Looks like you put them right in the hot air stream from the radiator and oil cooler?
Yes! Well, it was snowing out while I designed them so I thought that would keep my feet nice and warm!!!
OK, there is no getting around it, if you go out further, the hot air will just hit your ankle.
Matt
How different are the old RS to the new RT brackets?
Can the old be retro-fitted ?
If not can they be traded-in ?
installation
Looks great! How easy to install? Now can you move the brake lever?
RT-S PE#0803
highway peg installation
Matt will the RT need to be on a lift to install or can they be installed by using a set of car ramps to get the front end up off the ground some?
They are similar, but the RT brackets are 2 inches longer. If you cut your old brackets and weld in a 2 inch section, they would actually work. There are some other small differences. It would be easier to just buy a new set!
Matt
They install much like the RS kewlmetal brackets. I won't have the official install instructions done for 2 more weeks or so but you can read through the RS bracket installation instructions to get an idea. http://www.kewlmetalstore.com/downlo...68b01fca866898 You do have to remove the left side footpeg mount plate. That is so you can install a long bolt through the rear motor mount.
Matt
You can do this install on the ground. A lift just makes it easier.
Matt
I picked up a set of the RT pegs from Mad Matt on Saturday. I just talked to my dealer, Desert Dog, Fountain Hills, Az., and we will install them on Wed while he has the panels off to do my 600 mile check. He looked at the brackets and does not plan on putting the Spyder on a lift to do the installation. I will take pictures of the install and post them on Wed PM.
I also installed my Zumo 550 GPS as per Matt's guidance. Unless you have access to an extensive hardware supply, I suggest you contact Matt for a kit as the grade 8 metric bolts and metric spacers are very hard to find.
RT-S PE#0803
RT-S PE#0194
kewl pegs
Matt,
Can't wait for my pegs to come in. Like the way the fit and ride on my 08. I'm sure i will love them on my RTS.
Vwatso 0194
