Results 1 to 8 of 8
    Jan 2019
    North Carolina
    Default Is there a good source for Lower grill panels, hopefully OEM?
    Hi folks, 2014 RTS.
    Is there a good source for the lower grill panels?
    I see the aftermarket, looking for hopefully original?
    Thanks in advance!
    Last edited by Peter Aawen; 04-01-2024 at 06:35 AM. Reason: Expanded title to briefly ask the question... ;-)
    Active Member DickB's Avatar
    Jun 2021
    FL
    I recently bought this 2014 RSS with many body parts missing due to a minor crash. Here's how I found parts.
    Look up part numbers here: https://epc.brp.com/. Do a search on the part numbers that you need. You will get hits on new parts if available and used parts on eBay. Many of the new parts were not in stock at distributors but had to be ordered from the supplier, so it took up to 2 weeks to get some parts. I needed more than 20 parts but was able to find them all, some used but most new.
    2019 Ryker Rally
    2014 Spyder RSS
    Vermont
    Quote Originally Posted by Jackhartjr View Post
    Hi folks, 2014 RTS.
    Thanks in advance!
    HI Jackhartjr.
    Are you looking for the side grills?
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Jan 2019
    North Carolina
    Yes please.
    Your answer to Deanna's question is somewhat confusing because you answered Yes to "side grills" but you originally said "lower grill panels." Do you mean the OEM plastic grills in front of each radiator? If so, you are looking for PN 705008132, Radiator Grill (quantity 2 L&R interchangeable), $49.99 ea, and there's quite a bit of disassembly of the Front Body Assembly to replace them. If you are looking for the left and right grills in front of the rider's feet, you are looking for PN 705004803, RH Side Grill, $28.99, and PN 705007307, LH Side Grill, $28.99, some disassembly required but much less than for radiator grills.
    You say you "see the aftermarket, looking for hopefully original." By that do you mean something like in the picture below? If so, those are stainless steel mesh Keep Out The Trash (KOTT) Grilles sold by Spyderpops that are affixed to the front body assembly in front of the OEM radiator grills. No disassembly required.
    Just what are you looking for?
    Jan 2019
    North Carolina
    Thanks, actually I'm looking for the ones in front of your feet.
    The part numbers are very much appreciated!
    Jan 2019
    North Carolina
    JayBros, thanks for information, I ordered one from my dealer the other day!
