Results 1 to 25 of 33
    Apr 2020
    Edgerton,WI
    Default To do….or not to do? Should I replace these BEFORE they fail?
    2019 F3L. 14,000 miles
    Due to the high failure rates of the Park Brake Motor and the Left-Hand Multi-function switch - TSB’s were published highlighting their failures…. Would I be over-reacting to just replace them before failure? I would install them…. cost is $750 for the parts. My thinking is to avoid the inconvenience of the breakdown, towing, trying to find the part, hotel stay, etc.
    It’s like: when do you replace an air filter, or a fuel filter……. when the engine fails to operate? I think they call it Preventive Maintenance.
    OR: Do I just Buy and new Sea to Sky?
    Last edited by bikerchris1270; 02-28-2024 at 08:41 AM. Reason: Expanded title to briefly ask the question/s... ;-)
    2019 F3L , Covid Blue
    Mar 2010
    Illinois
    The old adage says "If it ain't broke-don't fix it".
    Sep 2016
    Chillicothe, Oh.
    I wouldn't.
    2015 RT , Black
    Jun 2011
    Alamogordo, NM
    Interesting justification to get a new Sea to Sky.
    I hope it works for you.
    Dean O
    Gran Pa Hoon
    Founder San Jose BMW
    Alamogordo, NM
    '20 Spyder F3 L
    First, you have to ask yourself, 'What is a high rate of failure?' I can't give you a scientific answer. But my guess is it's probably in the 10% range. That means you have a 90% chance of not having a failure. Nor will replacing it give you a 100% chance of never experiencing a failure.
    I'd run with what you've got. But that's me. You should do what makes you feel comfortable.
    Quote Originally Posted by bikerchris1270 View Post
    I don't recall that the "Park Brake motor" has a high failure rate ..... and the lefthand cluster began having failure issues only in the past couple of years ..... which to me means a replacement may be of the generation of High Fail rate .... The ORIGINAL DESS module (08 to 13) had an extremely Low failure rate .... then in 13 some engineer decided to re-invent it ..... and bang, they started failing ..... IMHO, leave well enough alone! .....Mike
    Last edited by Peter Aawen; 02-27-2024 at 02:59 PM. Reason: Fixed quote display ;-)
    Active Member Stache's Avatar
    Apr 2020
    Flatrock, NL, CA
    You could go with the best of both worlds - buy the parts, replace them if they fail. Of course that leaves open the question - should you buy a complete replacement machine so that, no matter what fails, you have the part?
    To each their own level of paranoia I guess....
    MWO (Ret'd) SJ Barnes
    ‘20 RTL Stone Grey
    named Britannia in honour of EE Doc Smith’s
    Grey Lensman’s ship.
    Farkles:
    Bestem Carplay
    canamsypderaccessories hitch and wiring harness,
    showchrome trunk rack,
    12v AND dual USB direct to battery in the frunk,
    dual USB switched in the blank console switch spot (parasites the power off the seat heater switch),
    frunk lid organizer,
    trunk organizer,
    showchrome rider backrest,
    ryder and passenger cup holders,
    ram mount for the iPad mini I use for GPS
    quadlock phone mount
    Nautilus horn
    Data blocker on the glove box USB
    Big Bike Parts highway pegs
    Spyderzone dash pouch
    Convex mirrors
    ‘20 Ryker 900 (my wife’s ryde)
    Farkles
    Slingmods fwd/rev ‘suicide shifter’
    frunk organizer
    dual horn
    Max mount
    Rear seat with tall back rest (not mounted)
    Ryder backrest (not mounted)
    Side bag
    Top bag
    top bag makes a good backrest. Will swap on the rear seat if she ever wants to 2up
    2020 RT Limited , Stone Gray
    Apr 2020
    Edgerton,WI
    Quote Originally Posted by Stache View Post
    Excellent, I’ve been diagnosed as Paranoid…….that’s what my problem is.
    Oct 2021
    Wichita, KS
    Quote Originally Posted by wolfeman View Post
    Ther old adage says "If it ain't broke-don't fix it".
    I wouldn't.
    Peter Pan has struck again!
    Buy the StS. You know you want one. That will also take care of the issue of to fix or not to fix.
    Northern Kalifornia
    I'm not sure exactly what the percentage of spyder failures is but they do not have a stellar reputation. I've taken it all in stride and keep my fingers crossed that I don't have a failure. But if I do I'm prepared to make an adventure out of it and see who I'll meet and where it will take me. Just not to the hospital, I hope.
    Apr 2020
    Edgerton,WI
    It would be good to know the percentage of failure for the Left Hand Combo Switch and Park brake motors so as to warrant a TSB and a new service part number.
    Buy the S2S and tow the F3L behind it. That way if one goes out, you just jump on the other one. Might have a negative effect on fuel mileage. But you'd solve the failure issue.
    Mar 2010
    Illinois
    Excellent answer Ron.
    Mar 2017
    Salisbury,NC
    WE NEED AN LOL button, not just like and thanks for post!!!!!!!!!!!!!!!!!!!!!!
    Aug 2019
    Stoughton, WI
    Well .... You know what I did
    2022 RT Sea To Sky
    Active Member AndysF3S's Avatar
    Jul 2023
    Alberta
    This is an excellent forum but, very few failures have been reported and considering that percentage wise very few owners are actually on here I would tend to enjoy the ride and repair only when its broken; although that may be inconvenient and more costly.
    Jan 2021
    Descanso, CA
    Thumbs up
    ARtraveler demonstrated the wisdom of his years. Well-framed and lighted photographs will really help sell your Spyder.
    Florida Swamp
    Have you got all the spare parts, belts, hoses, fuel injectors, plug wires and all the other parts for your car just in case something should break?
    Think about it................
    2019 F3-S , Black & Silver
    Apr 2020
    Edgerton,WI
    Yeah, I know... where do you think the idea came from?
    Quote Originally Posted by Gwolf View Post
    A whole lot easier to find parts for a domestic vehicle than a Spyder Dealer.
    Ok, I’ll ride it until the new ride arrives... Thank you all for your input. Have a great day!
    Aug 2018
    Ohio
    It Happened to me
    Speaking as someone that had our '19 RTL switch cluster fail after many intermittent parking brake problems... I might think about replacing it for my own peace of mind.
    Last edited by Peter Aawen; 02-28-2024 at 08:11 AM. Reason: Removed Post title - they mess with Searching! ;-)
    Feb 2020
    CT and ME
    Wait until it fails. Have the bike towed to dealer then trade it in for a new one.
    My Mods:
    Elka Stage 5 rear shock with spring preload adjust
    Monster Stage 2 ECU
    Pedal Commander
    RLS cat delete
    Baja Ron sway bar
    Baker Air Wings upper and lower
    Viking saddle bags
    Third pegs
    Vredestein tires front and rear
    Mad Stad windshield
    X-creen windshield deflector
    Front and rear drive cam
    Garmin Zumo XT
    Heated gear wiring
    Lamonster LED headlights
    Lamonster LED foglights
    Lamonster frame mount cupholder
    BRP heated handgrips
    Lamonster drivers backrest
    BRP passenger backrest
    Lidlock handlebar end helmet locks
    Barkbusters Storm handguards
    2020 F3S-SS , Titanium/Black
    Apr 2020
    Edgerton,WI
    Quote Originally Posted by Yabbadabbadoo View Post
    Well yeah, eliminates having to shop around for best price and product availability.
    Durham,Maine
    Good Luck with the new one!!! Now you have a warrantee to ride under, a payment book and maybe a dealer to take it to!! Unless you paid cash for it!
    2012 RTL , Pearl
    indpls in
    i have 50000 miles on my 21 rtl and wife has 30000 miles on her 21 rtl only issues fuel pump on hers fan relay on mine ride more worry not
