Results 1 to 22 of 22
    Apr 2020
    Edgerton,WI
    Question What's the consensus on Kenda KR 20 rear tires? Better than stock?
    What is the consensus of opinions for the Kenda KR 20 rear tire? Is there an improvement over the stock Kenda? My OEM Kenda wore the center of the tread down in 6000 miles, I do pull a 200 lbs trailer. Just wondering if Kenda aftermarket attempt is an improvement over OEM.
    Last edited by bikerchris1270; 02-16-2024 at 05:36 AM. Reason: Expanded title to briefly ask the question/s... ;-)
    2019 F3L , Covid Blue
    Harrington, Australia
    What type of “improvement”, Chris?…..performance? longevity?
    Out here in Oz, they work pretty well. The local service guy recommends the Kanine, and is seeing around 25-30,000km out of them. (15-20,000 miles)…..while the stocks get 15-20,000km. For some reason, our roads seem to be more forgiving than the US.
    I have not noticed any difference in handling between the rear stock and the Kanine in wet or dry……both rear tyres work well(around 10,000km on each).
    Bear in mind, we are only talking the rear here. I have Goodyears on the front (I probably would have gone with Kanine on the front, simply for consistently, but you couldn’t get them during Covid). The Goodyears work very well also.
    HeliBars Handlebars
    Kenda Kanine rear.
    Nov 2018
    Waynesboro, PA
    I used the Kanine 20 all around and they work great for me. lots of grip, no issues at all, I will use another one on the back once this one is done (I have about 8k on it so far), if I can find them.
    My Spyder
    2012 RTL , Brown
    The KR 20 is not worth the money compared to most Auto tires, which will give 30,000 mi. to almost 50,000 mi. ..... Mike
    Active Member Old Prof's Avatar
    Sep 2015
    Columbus, Ohio
    I'm curious....what is your personal recommendation in an American tire for your RT? Thanks.
    Last edited by Peter Aawen; 02-15-2024 at 05:51 PM. Reason: Fixed quote display ;-)
    2016 RTS SE6
    '64 Honda CA95 "Dream"
    Active Member T.P.'s Avatar
    APPLE VALLEY, MN
    https://www.tirerack.com/tires/vredestein-quatrac
    The QUATRAC is one of the favorite tires here for a few years.
    165/60R15 or 175/55R15 fronts, 205/60R15 rear 17/18 psi fronts and rear
    There are other members who have there Favorite's also. MRS.T.P. and I both run Quatrac's
    T.P.
    Quote Originally Posted by Old Prof View Post
    I have recommended "Vredestein's" (any model) for years (front &/or rear)..... I now personally use tires from RIKEN for the rear ($20.00 less) from TireRack ..... and 8,000 mi. in all kinds of weather I really like it ..... Mike
    Active Member RudyB's Avatar
    May 2016
    Abbotsford British Columbia Canada
    On the front yes not on the back lol
    Aug 2019
    Stoughton, WI
    What size rear Riken?
    2022 RT Sea To Sky
    Active Member MNBK's Avatar
    Mar 2017
    Circle Pines, MN
    I put Vredestein Quadtrac 175/55R15 on the front and Riken Raptor HR 215/60R15 on the rear. I had the Kanines all the way around and didn't think that they were much better than the originals. I listened to Mike (BlueKnight911) and went from Minnesota to Buffalo, NY and back home and I was very happy with the way they handled. I was caught in several frog strangling rains and never had any reason to be concerned.
    Just my experience.
    Dave....
    2016 Red/Black F3T w/ Audio
    Bajha Ron Swaybar, BRP driving lights
    F4 Windshield, Ultimate Tallboy Seat
    BRP Passenger Backrest
    Custom Dynamics fender lights
    Tricled Rear Bag lights w/ Flashing Brake Modulator
    Wolo Horn, Lamonster's Bungee Buttons
    Spyderpops Bumper Skid
    215/60-15 ....... Mike
    Quote Originally Posted by RudyB View Post
    ???????? - this relates to what post here ...... Mike
    I’d say it relates to the very first line of the original post, Mike…..an opinion of the KR20 on the rear.
    HeliBars Handlebars
    Kenda Kanine rear.
    OK, I guess he's not aware of the "Reply with Quote feature" ..... which simplifies things a lot .....Mike
    Jan 2015
    southern WI
    I sure do like the General Altimax for the rear. Our 2021's both came with crappy Kendas and they were both shot under 10k miles.
    2016 RTS , Pearl White
    Aug 2019
    Stoughton, WI
    I'll run my new (820 mile) OEM Kenda this upcoming season, but a Altimax/Vredestein/Riken will be its replacement over winter storage.
    2022 RT Sea To Sky
    Oct 2020
    Arizona
    On my Champagne 2018 I first put Federal Formoza on the front and a General Altimax out back. I then bought PPA wheels and Vredestein's for the front. Vredestein Quatrac handle the twisties a little better than the Federals with a BajaRon sway bar.
    Recently I bought second 2018 and moved the PPA wheels and Vredestein Quatrac to it, put the OEM wheels Federal back on the Champagne one. The new Asphalt Grey one came with Elka shocks on the front, I added a BajaRon sway bar, and it is a monster in the twisties. It has a Kenda (AKA bicycle/wheelbarrow tire company) out back and next fall when I get back to Arizona I will install a car tire on the rear. My plan is to Fly back to AZ in early June and ride the Champagne one to WA as my summer trike. Sig line has a picture of both of them. The KRX SxS will commute back and forth on a trailer.
    Sep 2008
    TX
    Quote Originally Posted by bikerchris1270 View Post
    We have had Kanines on 2 F3s and will address your question directly: they are vastly better than the OEM Kenda tires. They wear flat across the face and we're still counting miles at 15K and they are in good shape (I don't have a tread depth measurement). They have better traction, wet and dry, than the OEM tires. The one tire we tried early on was a Kumho, which was worse for wear (out of round tread depth) and traction, especially in wet conditions, compared to the OEM Kenda. As far as mileage, most riders on this form will age out of a 40K mile tire well before they actually wear the tire out.
    OEM Kenda tires will. indeed, wear the center out on the tire. Although once it reaches a point, the shoulders start wearing down vs the center. We have run the OEM Kenda tires well over 16K miles.
    pauly1 - SpyderDeb's 'wrench'
    IBA #48220 SS1000 BB1500
    Quote Originally Posted by pauly1 View Post
    For your own benefit read BAJARON'S post from today about Kenda tires..... He has an excellent explanation ...... Mike
    https://www.spyderlovers.com/forums/...01#post1698101
    Apr 2020
    Edgerton,WI
    How one question can go 9 different directions……..thank you for answering the question. ��
    Feb 2020
    illinois
    On my second Spyder and have no issues with the oem tires. Been in 29 states from Oregon to New Hampshire to Florida and Mexican border with these two bikes. All kinds of weather and road conditions. Can't say anything negative about how the bikes handled or how the tires wear. I am not big on checking air pressure that much. Have 11K on back tire of the 2022 F3Limited and looks like little wear. We all have our likes and dislikes about almost everything. As long as you're happy with what you have, so be it.
    Unfortunately, so many people want to “see their name up in lights”, Chris, and take threads (and FB questions), down ratholes for that reason. . Sometimes it is accidental, but most times…….not
    HeliBars Handlebars
    Kenda Kanine rear.
