Results 1 to 3 of 3
    Feb 2024
    Missouri
    Default Which LED & Fog Light..?
    Is there a major difference between Lamonster H4 LED Headlight and Slingmods Elite LED HD 360 Headlight Conversion Kit in regards to brightness/clarity.
    Same questions for fog lights, Lamonster IPS™ F3 LED Fog Light Kit versus Arc LED Daytime Running Light / Fog Light Replacement Kit. The later has daytime running lights, but is either brighter..?
    Thanks!
    Member ZiggyF's Avatar
    Aug 2023
    Florida
    I can’t give you a comparison but I have the Slingmods & couldn’t be happier. My thoughts are they really can’t be much different.
    2014 Can Am Spyder RTL Chrome Edition
    Led Headlights & Fog Lights
    Frunk Organizer
    Rear Trunk Organizer
    Painted Windshield Bracket Black with Chrome Spyder
    Leather Like Foam Hand Grips
    Handlebar Weights
    Plug N' Play Brake Light Flasher / Modulator Kit
    Trunk Mounted Run, Brake & Turn Signal LED Light Kit
    USB/Volt Meter
    2 - Airhawk - R-REVB Cruiser Motorcycle Seat Cushions
    Led Undercarriage Lights
    Show Chrome Full Size Brake Pedal
    Show Chrome - Chrome Handlebar Cover
    UltraGard Essential Half Cover
    Polished Stainless Steel License Plate Frame
    KEMIMOTO Motorcycle Bottle Holder
    Bluetooth 5.0 FM Transmitter
    Hopnel Trunk and Saddlebag Cargo Net System
    TackForm Center Mount Phone Holder
    Trunk Mount Dual Flag Holder
    High Way Pegs
    Baldwin Ironworks Cat By-pass
    K & N Air Filter
    Magnetic Mirror Mounts
    Kenda Kanine Tires
    Originally from Medina, Ohio
    Currently living in The Villages, Florida
    Very Active Member CloverHillCrawler's Avatar
    Mar 2021
    Maryland
    I have the IPS fog lights and they are great. They put the led headlights to shame which are pretty bright as well. I use them regularly so I can see the glow in deer's or other animals eyes while they are still off of the road in the trees on some of the secondary mountain roads around here.
    Unfortunately they are not bright enough to shine through a panel truck in a driveway that deer can hide behind.
    2020 F3 SE6
    Safety and Lighting: LED Headlight upgrade, IPS LED Fog lights, Show Chrome LED Fender Signals, LED Signature Light, Tric LED Afterburnerz, MotoHorn 2.0
    Suspension: Wilbers Front and Rear Shocks, BajaRon Sway Bar, Vredestein Quatrac Front and Rear Tires
    Comfort: Blue Ridge Windshield, Corbin Dual Touring Saddle, Ultimate Floorboards, OEM Passenger Backrest with Rear Shelf, OEM Passenger Floorboards Modified with High Risers from Pierre
    Tackform Center Mount Phone Holder w/ rapid charging USB-C.
    2020 F3 , Black
Tags for this Thread
