Results 1 to 11 of 11
    Mar 2021
    Maryland
    Default Has anybody found a 1157 LED replacement that doesn't cause hyper-flash?
    Has anybody found an 1157 LED bulb that doesn't cause hyperflash on a 2020 F3?
    I bought some these AutoOne 1157 bulbs https://www.amazon.com/Lights-AUTOON.../dp/B09W4C1D4K
    I need to replace the current ones due to when I have the afterburner lights on that I have installed it is drowning out the dim incandescent bulbs of my brake and turn signals.
    The autoone led bulbs are definitely bright enough to fix the issue but I am getting a weird hyperflash after doing the lamonster hyperflash fix.
    While I am in full motion the bulb does not hyperflash but slow down or stop (even with the brake off) it hyperflashes.
    I just read in another thread that the hyperflash fix has to be done with the engine running so I will give that a try first as I did the fix with just the ignition on and not running.
    But if I need to get a new set of bulbs who has used one that works without hyperflash?
    2020 F3 SE6
    2020 F3 , Black
    Quote Originally Posted by CloverHillCrawler View Post
    Yes there are brands that don't HYPER-FLASH, however what's BAD about that .... IMHO it's MORE noticeable in Hyper-Flash .... and that's a good thing. .....JMHO ....Mike
    Mar 2021
    Maryland
    I am just worried about the hyperflash causing canbus errors or throwing codes.
    2020 F3 SE6
    2020 F3 , Black
    Nov 2015
    Chardon, OH
    Well, it’s the same old thing. Unless you want to add a separate load resister, you need to buy a bulb with the load resisters built in. The bulbs you bought don’t have it. States that in the product description. Google will give you some choices, but they’ll run you around 50 bucks for a pair. It’s a two circuit bulb.
    Doug
    ”Freedom is not a loophole”
    Mar 2021
    Maryland
    I forgot to change the bulbs out to try the hyperflash fix with it running today, I was hot to trot after getting my cat delete installed and started it up to let the ecu adjust for about half hour and did a face palm when I remembered I wanted to put those in before I started it.Oh well off I went out on a 2 hour test drive this afternoon.
    I'll try the fix tomorrow with it running and if it is a no go I'll go get the resisitors. I just didn't feel like splicing into the lines under the seat, guess I'll have to if the hyperflash fix doesn't work again.
    2020 F3 SE6
    2020 F3 , Black
    Sep 2019
    West Bend,Wi
    Go to Amazon and search for an 1157 LED bulb with built in resister that’s Can-Bus ready.
    Loving my 2020 RT-L
    Active Member WDAVEY's Avatar
    Jul 2019
    FL in winter, CNY in summer
    Clovercrawler - Auxito makes LED signal light bulbs with built in resistors, so you don't have to splice any wires. On my 21 RTL the original signal light bulbs were not 1157. The correct bulbs have pins on the side of the socket that are NOT 180° apart like the 1157. I no longer have the PN of the bulbs, but their website is very helpful. 2 bulbs were about $30 two years ago.
    2021 Spyder RTL chalk/black/chrome bought in March 21. Previous rides: 2019 Spyder RTL, Orange/chrome. 2015 Harley Heritage, 2002 Harley Heritage, 77 Harley Electra Glide, 75 Harley Electra Glide, 72 Harley Sportster (first bike bought new)
    My Spyder Mods
    Rider backrest, F&R cup holders; F3 handlebars; BRP LED driving light; LaMonster front fender and mirror turn signals, LaMonster Saddlebag lights, Auxito LED rear turn signal blubs w/ built in load resistor; Brake lite modulator/flasher; LaMonster flags on trunk; Garmin Zumo XT. LaMonster Bluetooth adapter for Phone & GPS through Spyder speakers. LaMonster floorboard risers; FOBO tire pressure monitors, Vredestein front and rear tires; BajaRon sway bar.
    Mar 2021
    Maryland
    Yea those are different, mine has 1157's in it now and I have a 2020 F3.
    Thanks I'll take a look at them to see if a 1157 is available.
    2020 F3 SE6
    2020 F3 , Black
    Jul 2023
    AR
    You can reprogram the turn signals to not hyper-flash . . . you can look it up, but I believe the steps are:
    - with the key on (not running), hold the hazard button down for 30 seconds
    - turn off hazard lights
    - use the turn switch either left or right
    - after one flash of the turn signal, turn the bike off
    - repeat all steps for other turn signal
    - when complete turn bike back on and hyper-flash will be gone
    Mar 2021
    Maryland
    Quote Originally Posted by DaddyRhino130 View Post
    I had done that before following the lamonster video but what happened was that it did not hyper flash while in motion but once I slowed down or stopped it would start hyperflashing again which was a change from hyperflashing all of the time.
    I just read in another thread though that it works only when you have the engine running when you perform the hyperflash procedure so I have to go back and do that again as i did it with the engine off and ignition only on.
    I will retry the hyperflash fix with the engine running but it's 39 deg and raining here today so I will wait for a dry day so I can test it plus I still have to get the other 2 strips working on my afterburners before I can take it out in wet conditions.
    2020 F3 SE6
    2020 F3 , Black
    Sep 2016
    Chillicothe, Oh.
    I have done this exercise countless times. It works fine for awhile and then the hyper-flash is back. Sometimes I get a normal or what some consider a normal flash and other times I get the hyper-flash. I don't even notice anymore. If they are flashing they are working and I don't worry about it. I have never had a code or canbus issue in 15,000 miles because of this.
    2015 RT , Black
