Results 1 to 3 of 3
    Active Member Clary's Avatar
    Feb 2015
    Nova Scotia canada
    Default Recommendations for a Rear tire, make and size, available in Canada?
    What would the Forum recommend as a rear tire replacement for my 2014 RT limited other than Kenda? Also, something that can be purchased in Canada. Thanks.
    Last edited by Peter Aawen; 01-08-2024 at 05:14 PM. Reason: Expanded title to briefly ask the question... ;-)
    Dec 2013
    Have you done any reading on this Clary? There's a lot on the Forum about tires already, even threads like this:
    https://www.spyderlovers.com/forums/...s-Please-*****
    Even just a couple of minutes of reading should give you a very good idea of which tires are being used successfully and what sizes work.
    And the reality is that just about any reasonable quality auto tire with a load & speed rating that matches or exceeds that of the OEM Kendas will, when run at the right pressure for the (lighter) load of your Spyder over that of a car, likely be an improvement over the Kendas.
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Feb 2015
    Nova Scotia canada
    Thanks guy, your right all I needed to know was there.
