Results 1 to 5 of 5
    SoFlo
    Default 2014 thru 2019 RT series OEM Rear Shock Assembly.
    Would like to find a rear shock assembly that came as oem on the 2014 thru 2019 RT series.
    The shock itself can be leaking, or failed, as long as the damper portion is intact for measuring length, stroke etc.
    Exploring the desire to build a modified Fox Shox for the rear of our 2014 RTS.
    Nov 2016
    Edinburg,VA
    You looking for an old shock? PM me...Andy
    SoFlo
    Quote Originally Posted by Genradman View Post
    Yes, ideally, a failed oem rear shock from a 2014 thru 2019 RT series Spyder for minimal money. No plans to run it. Simply need some dimensions so I can modify / build a Fox Shox to fit.
    Will pm tonight as time permits.
    SoFlo
    PM sent to Andy as requested.
    Still looking if anyone has an oem rear shock from a RT series from 2014 thru 2019.
    SoFlo
    Still on the hunt
