Results 1 to 9 of 9
    Active Member BamaJohn's Avatar
    Feb 2015
    Talladega County, Alabama
    Default Vredestein Quatrac 5 news
    FYI....Vredestein's reply to my inquiry trying to find a Quatrac 5 rear tire for my 2020 Spyder RT (205/60/R15):
    Thank you John for your email.
    We no longer make the Quatrac 5 in that size. It has moved over to the Quatrac tire.
    My current rear tire has a tiny hole which I've plugged, so am looking for a replacement rear tire....(current tire has about 11,000 miles on it).
    John B.
    Current ride: 2020 Spyder RT-s Petrol Metallic Blue dark with OEM top case
    Mar 2021
    Maryland
    This is what I have/had on mine until my rear end accident and it was replaced with a kenda, I will go back to the Quatrac once the kenda does it thing and wears out in the middle.
    I had about 22,000 miles on my Quatrac when it was replaced and probably had about 7-10,000 left on it when it was removed.
    https://www.tirerack.com/tires/tires...R6QT&tab=Sizes
    2020 F3 SE6
    2020 F3 , Black
    Active Member MeudtPG's Avatar
    Aug 2018
    Monroe, WI
    VREDESTEIN QUATRAC is a great choice and I think you will like them!
    I ran the VREDESTEIN Quatrac 5 - 205/60R15 at 18 PSI but tire had a tire date of SEPT 2016 so now all my tires are over 7 years old and time to get fresh tires.
    Just mounted and balanced these brand new VREDESTEIN QUATRAC tires.
    REAR: VREDESTEIN QUATRAC 205/60R15 and both new front FRONT: VREDESTEIN QUATRAC 165/60R15 tires from Tire Rack with date code May 2023. Complete set was delivered next day for $358.00!
    The salt trucks are running around here in S. Wisconsin right now, but my 2018 Spyder RTL is ready to go. They should be awesome!
    "BLUE STAR – She shines so brightly"
    2018 SPYDER RT LTD SE6 BLUE/CHROME
    2018 RTL , Large Brake Pedal (cut 1/3 off). Oxford Blue/Chrome
    Quote Originally Posted by BamaJohn View Post
    Not surprising. The Quatrac 5 has been discontinued for quite some time. And why would you want one when the current Quatrac is a superior tire?
    Feb 2015
    Thanks Ron...didn't know the 5 had been gone a while. I have replaced my knowledge bank, with Quatrac being my current choice......
    John B.
    If all you have is a tiny hole in the tread area. It would be a waste to replace the tire if it has good tread life left. It's not like we are riding 2 wheels where a flat can be extremely dangerous. Of course, a flat is never fun, regardless of the danger or lack thereof. But you could be riding down the road on a brand new tire and get a flat.
    A decently patched tire, especially a rear, on the Spyder is not something I would be concerned about.
    IMHO, when riding TWO wheels you are using Mtc. tires which Spyders don't use ..... Car tires are constructed differently than Mtc. tires and take a plug much better .... Ride it with the plug .... Mike
    Feb 2015
    .... A decently patched tire, especially a rear, on the Spyder is not something I would be concerned about.
    Both comments align with my actions. I only posted that the Quatrac 5 was discontinued (thinking it was news). The tire has over 11,000 miles on it, so I plugged it and will ride it until the tread is gone.
    But I did order a new Quatrac yesterday to have on the shelf, just in case.
    Last edited by Peter Aawen; 12-03-2023 at 07:40 AM. Reason: Fixed quote display ;-)
    John B.
    Sep 2020
    Middletown, NJ
    I liked the Q5 tread pattern up front because of the asymmetric design that pushed standing water to the outside. Seemed less of a benefit on the rear.
    The Q is symmetric and pushes the water to both sides - better for the rear IMHO.
    Either tire is an excellent choice for the Spyder.
    2020 RT base , Chalk White
