Results 1 to 7 of 7
    Jun 2015
    Ritzville, Wa
    Default How tight should the oil drain plug be?
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    indpls in
    not that tight just enough to seat the orings
    Most, including dealerships, get these plugs way too tight. They only need to be mildly snugged. I like to use a stubby 3/8" ratchet and even then, not put a lot of pressure on the plug.
    I've never seen a plug fall out or even leak. But I've seen many that were stripped from over tightening.
    ...forget the Torque wrench ..... snug the socket wrench then a light tap to finish ....if it leaks so what, just tap it again .....JMHO .... Mike
    Aug 2013
    SF Bay Area
    Torque to the specs in the owners manual. They get tighter when the engine gets hot during normal riding.
    2021 F3 Ltd , Magna Red
    Feb 2016
    To answer the question -
    On the oil sump cover - 21 lbf/ft + or - 1
    On the clutch cover - 15 lbf/ft + or - 1
    And on the oil filter cap - 18 lbf/ft + or - 2
    2020 RT Limited , Marsala Red
    Aug 2023
    Central Florida
    Personally, I go by the mfgr’s torque specs.
    I have had car dealers tighten the plug so tight that I had to use an extended socket handle. Can’t trust those buggers.
    SP
