Results 1 to 3 of 3
    Jan 2024
    South Dakota
    Default 2012 RS - how do I remove the Headlight Assembly without prying on plastics?
    Hey Guys,
    I'm trying to change out the headlight assemblies on my wife's Spyder. She wanted a set with halos, so now I am obligated to install them. I believe I have removed what I need to except for the black plastic cluster housing. How do I get this off without prying on the plastics? Any help would be appreciated.
    Regards, Robert
    Last edited by Peter Aawen; 01-26-2024 at 05:49 AM. Reason: Expanded title to briefly ask the question... ;-)
    Bossier LoUiSiAna
    From notes on general bulb change:
    RS headlight
    Best method...
    1. remove windshield;
    2. release gauges (small tabs in top) unplug the cluster and set it aside where it won't fall and break;
    3. remove turn signal arms (use care when removing plugs);
    4. along the top of the head piece are some tabs - use a small screwdriver to release the tabs & insert screwdriver between the halves to keep them open 'til all the tabs are popped open;
    5. lift top to open it (it will remain attached in front);
    6. then remove the rubber boot 1/4 turn the connector inside and slide the plug and bulb out - (Important! DO NOT TOUCH THE NEW BULB WITH YOUR FINGERS - skin oils will cause it to discolor and fail), so preferably, put on rubber gloves to remove the old bulb and insert the new one - insert it into the socket and turn till it stops (I did both at same time so I wouldn't have to go back in a month and saved the good bulb just in case.)
    7. Now test to make sure the lights work - on the right-hand grip's back side is a button, push it and the lights should flash on. If they work, re assemble the bike in reverse.
    Good luck and have fun!
    or:
    https://ourdiyblogs.wordpress.com/20...t-replacement/
    Jan 2024
    South Dakota
    Thank you! I'll give it a go.
