Results 1 to 19 of 19
    Aug 2008
    Sacramento
    Angry My Sad Spyder Story - 2022 F3 needs a new engine!
    I put 40k miles on my 08 Spyder in 2 years. BRP sent a new engine out when it blew at 21k, but after that I had problem after problem. I ditched the Spyder and switched to a Ninja for 80k and a Z900 for 70k. So I'm now at the point where my knees might let go whenever I stop the Z, so I sold the Z and bought a brand new 2022 F3 in Sept 23.
    After 750 miles, I took it into the dealer to install floorboards and wire up my heated gear. Waited patiently at the dealer while they did the work.
    Then ..... "Sir, you have an oil leak, and we don't recommend you ride it until the leak is fixed."
    OK, 2 weeks or so for the parts, then another week to fix, EXCEPT ...... when they started working on it after receiving the parts, they discovered a crack in the engine block!
    Now BRP is sending an engine out. I hope to ride it again before the end of the year.
    As someone who rides over 10k a year and rides all year long, this is driving me nuts.
    Tell me I didn't make a mistake buying a Spyder!! Gee, venting feels good.....
    Last edited by Peter Aawen; 11-09-2023 at 07:28 PM. Reason: Expanded title to briefly state the reason for this thread! ;-)
    2022 F3 Base
    Kawa Z900 - 72k
    NInja 650 80K
    2008 SM5 - 42k
    Two bad engines in a row? Don't waste your time on lottery tickets. I am not aware of that happening to anyone that has posted on this site. I have been around here since 2010, but have owned a Spyder since 2008. I got the first one delivered to a customer in Alaska. I have never had any major incidents with any of the seven Spyders I have owned. I put on over 200K miles across the board during my ownership of Spyders.
    I just sold a 2019 and a 2020 F3L. I considered them to be the best of all the Spyders I owned over the years.
    It sounds like you have had a real run of bad luck.
    Vermont
    I hope you get the new engine before end of the year!
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Bossier LoUiSiAna
    Cause of crack& warranty?
    Aug 2008
    Sacramento
    don't know the cause of the crack. I sure haven't hit anything...
    Luckily it is under warranty.
    I must say that I loved the 2008 spyder when it was running. Problems with it included the power steering going out, cracked , and finally some cracked steel struts in the front ( which were probably caused by the weight of the Corbin fairing).
    2022 F3 Base
    Kawa Z900 - 72k
    NInja 650 80K
    2008 SM5 - 42k
    Aug 2008
    Sacramento
    OOps, that should read " cracked swingarm"
    2022 F3 Base
    Kawa Z900 - 72k
    NInja 650 80K
    2008 SM5 - 42k
    Feb 2020
    Minnesota,USA
    Quote Originally Posted by Lowflyingowl View Post
    , so, what the ---- is cracked on which Spyder, or are we even talking Spyder?
    Sounds like your more concerned about 08 which you ditched, than the 22F3 that has something cracked!
    If in Doubt, Don't Do It!
    Florida Swamp
    I know your real name, Joe Btfsplk. You can't fool me.
    I even found a picture.
    2019 F3-S , Black & Silver
    Active Member BamaJohn's Avatar
    Feb 2015
    Talladega County, Alabama
    That sucks big time! Sure hate to hear & hope you have years of good things after the new engine is sorted out!
    John B.
    Current ride: 2020 Spyder RT-s Petrol Metallic Blue dark with OEM top case
    Active Member tntnj's Avatar
    Sep 2015
    JerseyShore
    Thank goodness you sent the bike in for some work done on it. Imagine if you were riding in a remote area and the block gave way and getting oil on the rear tire. Hoping you get your bike back soon You may want to ask for a loaner while you are waiting for a motor.
    2017 F3 LTD (SOLD)
    2017 HD Freewheeler (SOLD)
    2021 RT Base Upper and lower adjustable deflectors , Top case, Signature and lower lights, Baja Ron Bar, Back rest,Fobo TPMS, Garmin 396 , LED Fender lights, Rear LED turn and brake lights, Rear Brake light flasher, Rear Saddle bag LED lights, Battery tender, Lamonster Handle Bar Riser.
    Sep 2020
    Middletown, NJ
    Quote Originally Posted by Gwolf View Post
    2020 RT base , Chalk White
    Mar 2008
    Hesston, PA
    Since the intoduction of the 1330 engines back in 2014 there have been several reports of "POROUS" castings from the engine manufacture that leaked oil and required replacement...If fact, BPR wanted to epoxy at least one new owner's engine with some type of special expoxy...
    Do a site search and hopefully it will turn something up???
    larryd
    Aug 2008
    Sacramento
    Did the search and found some mentions of this problem.
    Guess I'm lucky that my dealer and BRP went directly to replacing the engine; some folks had to fight for months to get it corrected.
    Hopefully, in 6 months I'll have forgotten I ever had an issue! Can't wait to ride again!
    2022 F3 Base
    Kawa Z900 - 72k
    NInja 650 80K
    2008 SM5 - 42k
    Oct 2021
    Ontario
    With only 750 miles on the bike, I think they should have just replaced the bike.
    Are they doing anything for your lost riding time?
    Aug 2008
    Sacramento
    No,,, no mention at all....I'm sure I can make it up when I get the bike back. By now, I would have had somewhere between 1000-1500 miles
    2022 F3 Base
    Kawa Z900 - 72k
    NInja 650 80K
    2008 SM5 - 42k
    indpls in
    you could ask for another year of warranty
    Jul 2021
    IL
    A manufacturing defect can happen to any bike. I had several Triumphs over the years and never had a single major problem with any of them EXCEPT one had slight oil leak that could be fixed and Triumph ended up having to replace the crankcase which was apparently a tiny bit out of spec. After that the particular bike worked flawlessly. I never held it against Triumph and my experiences after that proved them to be reliable and trustworthy. As to the Spyder, my 2021 RT has not had a single problem, major or minor, since the day I left the dealer with it. I have 17,000 miles on it and could not be happier.
    2021 Spyder RT
    2023 Royal Enfield Hunter 350
    Retired U.S. Army
    Life Member, NRA
    2021 RT , Petrol (blue)
    Aug 2008
    Sacramento
    BRP shipped the new engine out and the dealer received it 2 weeks later. Today, I finally picked up the Spyder. Seems to run fine so far. Now I have to catch up on my riding....
    2022 F3 Base
    Kawa Z900 - 72k
    NInja 650 80K
    2008 SM5 - 42k
    Ride safe! And here's to there being no more need for new Spyder engines!
    Cheers!
