Results 1 to 6 of 6
    Active Member johnv50's Avatar
    Jun 2018
    Tonawanda, NY
    Default Any easy way of Searching for active FM channels while driving?
    I have a 2022 F3T and have watched a number of you tube videos but cannot find an easy way to search for stations.
    When traveling a distance I need to find channels which are active in the area I am in. There must be an easy way to do this.
    Thanks in advance for your assistance.
    johnv
    Last edited by Peter Aawen; 10-25-2023 at 05:35 PM. Reason: Expanded title to briefly ask the question... ;-)
    USMC RETIRED
    BLUE KNIGHTS NYV
    2022 F3T Glacier Blue
    Quote Originally Posted by johnv50 View Post
    johnv
    BRP changed the radio system in 2018 ..... I have a 14 RT and if I go up or down the FM dial it will stop on a stronger signal. .... I also changed the OEM antenna for a Bosche retractable Auto unit and this improved my reception about 400 % ..... Good luck >>> Mike
    Sep 2020
    Middletown, NJ
    From Pg 35 of user guide:
    When FM audio source is selected, the
    left and right joystick functions will be
    as follows:
    - Short Left: Previous preset
    - Long Left: Seek down
    - Short Right: Next preset
    - Long Right: Seek up
    Hope that helps.
    2020 RT base , Chalk White
    Jun 2018
    Tonawanda, NY
    Thanks RayBJ, just what I was looking for, will try that tomorrow.
    johnv
    USMC RETIRED
    BLUE KNIGHTS NYV
    Very Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    Does your antenna auto retract or is it not but is for automobiles and you retrofitted it to your sypder?
    2021 RT Base - Petrol Blue
    Active Member WRCLVR's Avatar
    Nov 2022
    Georgia USA
    Hey can you give details about the retractable antenna? Where you got, price, difficulty of install, wiring for the power etc? I'd like to have this on my 2019 RTL as a better antenna as well as avoiding issues with my cover snagging the antenna every time I cover it when its out side....
    2024 RT SEa To Sky ( back at dealer again due to blank screen issues , loss of BT and WIFI :-( :-( .. looking forward to the BajaRon event May 1-5 just with 2023 S2S only)
    2023 RT Sea to Sky Shadow Green ( guess what NO errors at all in 9 months of owning....)
