Results 1 to 12 of 12
    Feb 2016
    Default Anyone else found an RT without the wire for lower front Auxiliary light?
    Between myself and numerous friends, we have all bought and installed the lower front auxiliary light on 2020 through 2023 RT's. Today I went to install one on another friends' 2022 RTL and found that there is no wire harness attached to the blanking plate installed in that location. I tried to look around and fish around through the hole to see if the wire connector was laying loose but with no luck. This is one of those bikes that shipped from the factory without some parts, notably the rear heated grips and switch. Has anyone else found a RTL without this wire? I assume that I'll have to remove the frunk to try to find the wire IF it's there...
    Last edited by Peter Aawen; 10-23-2023 at 05:02 PM. Reason: Expanded title to briefly ask the question... ;-)
    2020 RT Limited , Marsala Red
    indpls in
    yes i have
    Active Member tntnj's Avatar
    Sep 2015
    JerseyShore
    My 21 RT base had the wire behind the plastic plate. When I bought the light it came with a wire for that light.
    2017 F3 LTD (SOLD)
    2017 HD Freewheeler (SOLD)
    2021 RT Base Upper and lower adjustable deflectors , Top case, Signature and lower lights, Baja Ron Bar, Back rest,Fobo TPMS, Garmin 396 , LED Fender lights, Rear LED turn and brake lights, Rear Brake light flasher, Rear Saddle bag LED lights, Battery tender, Lamonster Handle Bar Riser.
    Feb 2019
    japan
    Lightbulb
    It is not included in the Japanese specification. Could it be a specification error on the production line? I feel like such mistakes can happen with BRP.
    Aug 2016
    South Wales UK
    The wiring is not fitted to European and British bikes as the lights are illegal here, same as the front accent lights are illegal.
    Feb 2016
    My friend has decided to take the bike back to the dealer to have them find and/or install the wire. Fingers crossed!
    Feb 2016
    UPDATE!! The bike did not have the wire installed from the factory. My friend allowed the dealer to fabricate a wire to the front aux light and all is well with him now. This bike came from the factory without the pax heated grips and switch and now this. I wonder what else might be missing?
    Dec 2012
    Murphy, NC
    Shouldn’t your friend request the BRP factory to ship the switch, wiring harness and pax grips to your dealer and install at no charge? Seems to me those items were paid for when your friend bought the Spyder.
    2020 F3 Ltd
    Spyderpops Bumpskid
    indpls in
    my friends came the same way dealer got grips and switch and installed
    Feb 2016
    Quote Originally Posted by JKMSPYDER View Post
    He did eventually get the grips and switch and the dealer installed them. It's only recently that he decided to add the front Auxiliary Light and we found the wiring was missing.
    Active Member spyderryder53's Avatar
    Hanover CT
    Mine came with the wire for the low brow light BUT no light in the FRUNK.
    2022 marsala red RTL
    AND
    2014 RT S SE-6 COGNAC, 2010 RT 622 TRAILER TIMELESS BLACK
    BRP trailer hitch, Utopia back rest, Baja Ron sway bar , heim links. Elka stage 2 shocks front and rear.
    TricLed fender lights, saddlebag lights and mirror lights. LED headlights and fog lights, Wide vu mirrors.
    spyderpops LED bumpskid ,zippered cargo bag linings, Laser Alignment by Netzleys Tire, Stebal air horn
    stant gas cap,( Dimple oil plugs REMOVED ) JT dash mount.
    (Onboard) Lamonster Garage air compressor and intelliboost charger.
    Bossier LoUiSiAna
    Just throwing this out there
    Has something to do with Kenda.
