Results 1 to 14 of 14
    Jun 2023
    Ontario
    Question Anyone know how to add a strobe/flasher to RT Brake Lights?
    Anyone know how to add a strobe or flash element to the brake lights on my 2023 RT?
    Last edited by Peter Aawen; 10-20-2023 at 11:45 AM. Reason: Removed Prefix - this is not a HowTo: DIY thread... & expanded title to briefly state the reason for the thread! ;-)
    Jul 2014
    Mint Hill, NC
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Active Member seaweed's Avatar
    Oct 2015
    Fort Lupton, Colorado
    I use a Magic Brake Strobe/Flasher (I not recall where I purchased it)
    I have had it for quite a while and like it.
    One issue is that if you ride with a group then you might want to a pattern that might not irritate fellow riders.
    Unless you are the sweep!!!
    I found my document. I bought mine from https://www.customdynamics.com/unive...-light-flasher, back in 2015. I see that the price decreased from $79.95 to $59.95.
    Dean Secord AKA seaweed
    Veteran: U.S. Air Force
    2015 RT-S SE6
    My Mods:
    TricLed Turn Signal, Squared Away Sept, 2016,SpyderPops Bump Skid, SpyderPops Missing Rock Guard, ION camera, Show Chrome Back Rest,
    Show Chrome Hitch. Leesure-lite trailer, Hopnel 850 Saddlebag Liners, Hopnel 3 piece lid netset - trunk and saddlebags
    Magic Brake Strobe/Flasher, DIY LED light strips on upper and lower A frames, BlueKnight911 Magic Mirrors,
    DIY superior grill, USB port, Hwy pegs, DIY Flag mounts for USA and US Air Force flags,
    Method to open Frunk and seat without using key, LED headlights and LED fog lights, turn signal switch safety mod
    Sep 2020
    Middletown, NJ
    The custom dynamics page referenced claims that flasher doesn't work with CanBus. I thought the Spyder was a CanBus. Are you using it on a Spyder?
    2020 RT base , Chalk White
    Jul 2014
    Mint Hill, NC
    Custom Dynamics did have a pattern-selectable plug and play brake flasher that I purchased in May '18 and really works great. In response to a question like the one from the OP about a year after my purchase, I looked at the CD website and could not find the Spyder flashing system so I called the company and was told they ceased offering it because it was being far outsold by the plug and play third brake light that RT owners could put the on the trunk lid. The price on the Sling Mods device is about half what I paid for the CD flasher but the SM device is just a straight flasher that is not pattern-selectable.
    Cognac 2014 RT-S
    Oct 2015
    Quote Originally Posted by RayBJ View Post
    Back in 2015 there was no disclaimer on their web site. Yes I put it on my 2015 RTS6. No problems with it interfering with CamBus.
    2015 RT-S SE6
    My Mods:
    Apr 2023
    FL
    Agree with JayBros. We have these on our cycle and they work fine.
    Chip
    2020 RTL
    "Stella by Starlight"
    UltraGard Full Cover, Front & Rear Cup Holders, Elka Stage 2 Rear Shock, TC & Dave Signal Button, Spyder Extras Sway Bar
    Idaho
    The lighting system on the Spyder is not CanBus, only the various processors like TCM, ECM, cluster, etc.
    2014 Copper RTS
    Active Member BamaJohn's Avatar
    Feb 2015
    Talladega County, Alabama
    Now, that's good information to have right there! Thanks.
    I, too, have the Slingmods brake flasher and like it.
    John B.
    Current ride: 2020 Spyder RT-s Petrol Metallic Blue dark with OEM top case
    Oct 2021
    Wichita, KS
    Here is what I use on my '22. Works a treat. Very simple install. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Peter Pan has struck again!
    Dec 2020
    Hartwell, Ga
    I installed one of these but only for the trunk, I left the others stock.
    https://www.amazon.com/Stop-Alert-Fa...21&sr=8-3&th=1
    Sep 2021
    Fredericksburg, VA
    Quote Originally Posted by K80Shooter View Post
    I've been wanting to do this.. Do You have a picture or instructions of the way you wired it up? Thanks in advance!
    RiderDuke
    My Ride
    2021 Glacial Blue Metallic F3-T
    Dec 2020
    Hartwell, Ga
    Quote Originally Posted by RiderDuke View Post
    No picture but, I removed the brake light from the trunk and with a voltage tester found the "hot" wire for the brake light when the brake pedal was applied. I cut the "hot" wire into here, I hooked the "hot" in from the switch here and the "hot" out the to brake light. I did run a ground wire from a known good ground under the passenger seat, I fitted a connector onto it where the wire harness connector is, at the front of the trunk so that it could be unplugged if I removed the trunk, then I ran it to the ground terminals of the switch (one on each side of the flasher) then on to the light. I added the ground wire as others had reported issues with the switch without doing this.
    There is room for the flasher to be left at the brake light, I attached it with velcro. Once everything is installed it is completely out of sight. I made up a diagram of what I did to mine.
    EDIT: Instead of removing the brake light, you remove the lower trunk latch and just unplug the brake light.
    Sep 2021
    Fredericksburg, VA
    Thanks for the help....
    RiderDuke
    My Ride
