Results 1 to 7 of 7
    Jun 2021
    Missouri
    Question Blinkers/4-ways stopped working - anyone else? Ideas?
    2019 RT Limited
    The only thing that works about my blinkers/4-ways is the green arrow indicator lights on the display.
    After one or two green arrow flashes, they start blinking faster.
    Tail lights, brake lights, headlights high/low, running lights all work fine.
    No blown fuses.
    Fender lights are on, but don't blink or "swipe"
    Anybody else seen this?
    Dave C
    Quote Originally Posted by CourVO View Post
    2019 RT Limited
    No blown fuses.
    Dave C
    The only thing I can think of is the common issue with folks that switched from Halogen / incandescent bulbs to LED's ..... the lowering of the resistance (?) with LED's can confuse the computer. ..... however lights that blink Faster are a lot more noticeable & to me that's a good thing .... Mike
    Jun 2021
    Missouri
    Thanks, BlueKnight....
    The blinkers don't actually blink faster...they don't blink at all.
    It's the green indicator arrows on the front display that blink faster...usually that means a glitch in the system somewhere.
    Equipment is all original...no switching of bulbs.
    Appreciate your response,
    Dave C
    Apr 2019
    PA
    I’m not sure what model you have and if this even applies but if I remember correctly the turn/blinker wire attaches in up by the mirror, I think. Could the mirror have pinched a wire or if you have magic mirrors when removing the plug could you have pinched, pulled, or stripped the wire? Again, I can’t remember, and I might be totally wrong, just thinking the union for them started or was up by the mirrors. When I hit a deer both mirrors were destroyed and none of my flashers or turns worked. The icon light on the dash rapid blinked until they reattached all the wires for the mirror. What model and year do you have? I have a 2016 RT book I just purchased when I needed help with my last repair.
    Idaho
    Are you saying none of the turn signals work, front and rear, either as turn signals or hazard signal?
    2014 Copper RTS
    Sep 2017
    Durham,Maine
    Relay?
    2012 RTL , Pearl
    Idaho
    Relay?
    There is no relay in the turn signal circuit. It's all controlled by software in the cluster.
    2014 Copper RTS
Tags for this Thread
