Results 1 to 8 of 8
    Member ImaCaMan's Avatar
    Jun 2020
    Salt Lake City, Utah
    Default Windshield Install - do I need the metal sleeves?
    My new windshield from Gustafson came today and when installing it, I found that two of the metal sleeves in the rubber bushings for the windshield holes were too small for the bolts to pass through. The other two were ok. I have left a message with Gustafson but don’t expect a reply till Monday.
    I looked at the JRock shield I’m replacing, and it just has the rubber bushings without any metal sleeve, so I’m not sure I really need them. I installed it anyway and will drive it. What do you think?
    This is a pic of one of the too small sleeves.
    Last edited by Peter Aawen; 10-06-2023 at 11:00 PM. Reason: Expanded title to briefly ask the question... & fixed attach display. ;-)
    2022 Spyder F3L Special Series, Red (Oceanside, CA)
    2018 Spyder RT Limited, Pearl White (SLC, Utah)
    Durham,Maine
    I would use them if I were you, there used as a limiter bushing, so you don't put too much pressure on the windscreen and cause a crack. Just my thoughts!
    2012 RTL , Pearl
    May 2014
    Benson, NY
    I wouldn't go without them either. I would be afraid of what might happen as a result in the future. Can you get a round file in there and remove enough material for the bolt to pass?
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Feb 2017
    What Mikey and Bensonoid said, unless Gustafson can convince you otherwise and you accept their position.
    2015 Spyder RT-S (Arion) and 2021 RTL Sea to Sky (charming wife)
    X's 4 ....what everyone above has said ......Mike
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    It depends on the windshield.
    The direction should tell you what to do if not, call them.
    I recently replaced my 8 year old shield with a Freedom from Lamonster.
    The Directions EXLICITLY state: Do NOT use spacers, rubber gaskets or screws and to discard them
    They supply new "washers" and screws. Problem was leaving the correct space for molding.
    I overly tightened and then backed off slowly until molding fit.
    Has worked fine over the last several thousand miles.
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Jun 2020
    My two round files were too big to fit. I tried to drill them out but wasn’t having any success. Since two did fit, I’m sure they will be sending me some more and hopefully I’ll get a fit for the other two.
    Jun 2020
    As a final follow up, Gustafson's came through and sent me some replacement sleeves. They fit and windshield is now securely attached. Thanks for your input.IMG_1911.jpg
