There is a service bulletin for 2020+ RT's for hard start issues. Requires an update to the ECM. If your battery is a little weak and barley turning the motor over enough to start this could cause the VSS warning. Check with your dealer about the Hard Start ECM update that my be all you need.
2021 Spyder RT Limited (Sea-To-Sky)
2022 Ryker Rally
Thanks all. It sounds like I may have a issue with hot starting which is causing the momentary showing of the "VSS FAULT". That is the only times I have seen the issue.
Ozzie Ozzie Ozzie
