Results 1 to 13 of 13
    Sep 2023
    nv
    Default My 2022 S2S has a constant RPM fluctuation - problem, or normal?
    Hi
    2022 S2S at idle, RPM's bounce from 850 - 900 constantly
    850 900 850 900 850 900 850 900 always the same. at each idle.
    problem or normal?
    Thanks.
    Last edited by Peter Aawen; 10-03-2023 at 05:14 PM. Reason: Expanded title to briefly ask the question... ;-)
    Sep 2017
    Durham,Maine
    I am going to say it's normal! Good gas, good air, it's new and wants to be ridden, get on that thing and go!!!Ride more, worry less!!
    2012 RTL , Pearl
    Aug 2020
    Niagara Falls NY
    Mine does it, not really meant to be an accurate indicator anyway. Roll that throttle and she purrrrrrs like a cat!
    Vince F in Niagara Falls
    2022 Spyder F3 Special Edition
    2020 Ryker Rally, sold
    2022 F3S , Stock Lamonster black diamond Monolith Black Satin
    ..... compared to the gas gauge or temp gauge ..... It's way close enough ..... my 14 was similar when new ..... Mike
    Sep 2016
    Chillicothe, Oh.
    Mine fluctuates as much as 100 RPM at times and since my digital tach reads in 50 RPM increments it really seems to be fluctuating, been that way since day one and I have a 2015.
    2015 RT , Black
    Jul 2014
    Mint Hill, NC
    Mine has done the same as Navydad's from the get go on the digital tach and the analog tach doesn't move at all. I detect no change in engine sound.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Very Active Member Jetfixer's Avatar
    Feb 2016
    Lake Wylie, South Carolina, USA
    It only reads in 50 rpm increments. So, in reality you might be seeing 875... perfectly normal operation.
    2020 RT Limited Deep Marsala Chrome
    2020 RT Limited , Marsala Red
    Active Member WRCLVR's Avatar
    Nov 2022
    Georgia USA
    Both my 2019 RTL and my new 2023 S2S show 800-900-800-900 constantly at idle even after riding. Never shows 850...Is there a way to get the dash to read in increments of 50?
    2019 has 4500 miles, the S2S 1100 miles
    Myabe i need to use some injector cleaner in both even though I use top tier premium fuel only ?
    2024 RT SEa To Sky ( back ahome after screen issues fixed looking forward to the BajaRon event May 1-5 )
    2023 RT Sea to Sky Shadow Green ( guess what NO errors at all in 8 months of owning....)
    Jul 2014
    Mint Hill, NC
    Save your money! That's exactly what my digital tach does. Even though I use Bajaron's iridium plugs, I change or have 'em changed at 28K, am less than 100 mi. from 87K on the roadster and have never put anything but gasoline in the tank.
    Cognac 2014 RT-S
    Feb 2020
    illinois
    What Mikey says
    Dec 2020
    Hartwell, Ga
    Lots or worrying about nothing IMHO.
    50 rpm's is nothing and honestly neither is 100 when the engine is at an idle. The gauges are electronic and will fluctuate.
    Aug 2007
    Greeneville, TN
    No ICE that I know of will idle without fluctuation. The 998 V-Twins fluctuate 200 RPM or more. The more cylinders, the less the fluctuation will be, as a rule. Though I think Wankel engines were more stable at idle.
    Now, if it were an electric motor under no load, I'd be more concerned.
    Ignore it and just RYDE!
    Jun 2011
    Alamogordo, NM
    Quote Originally Posted by WRCLVR View Post
    Top tier premium is is not a better or cleaner fuel than regular, the only difference for all practical purposes is it is harder to ignite and has a slower flame front, in other words, helps to reduce detonation or pre ignition.
    Dean O
    Gran Pa Hoon
    Founder San Jose BMW
    Alamogordo, NM
    '20 Spyder F3 L
