Results 1 to 24 of 24
    Nov 2019
    Kansas
    Default New back tire. Short valve stem. Do extenders exist that work?
    So like I said, new back tire, but the valve stem is really short, and I struggled to get the PSI down from 30-18 because it took some finangling to get something on it due to where it is at.
    So 15 minutes to get the pressure where I wanted it. So do these kind of things exist? Or not?
    2018 F3 Limited
    Aug 2021
    South Carolina
    You can purchase extenders at any parts store.
    Quote Originally Posted by acdcking12 View Post
    Whoever did the tire swap should have put on one that was a little longer ..... JMHO .... Glad you using 18 PSI .... Mike
    Nov 2018
    Waynesboro, PA
    Try a search on Amazon (tire valve extender)
    My Spyder
    2012 RTL , Brown
    Nov 2019
    Kansas
    Quote Originally Posted by CopperSpyder View Post
    I should have done that. But I look for your guys guidance. You all always get me going in the right direction.
    2018 F3 Limited
    Feb 2012
    Spring City,Utah
    Go to your nearest Harley store, It's fun anyway just to see all the pretty new Harleys. Ask for a rear tire valve extender. They use them on Ultras to check the rear tire. Last time I checked they were about $11. You can screw it on when you want to check the rear tire pressure.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Florida Swamp
    Get a trigger type hookup for the compressor hose with a gauge on it, so you can clip it to the valve stem and adjust the pressure with the air still hooked up. Get it where you want it, just un-clip the hose and ride. 5 minute job and don't need 4 hands to do it.
    2019 F3-S , Black & Silver
    Northern Kalifornia
    This has been posted many times before. Here is the correct tool with the correct angle to air up your spyder's rear tire.
    https://www.harborfreight.com/extend...iABEgKq3PD_BwE
    And here's a tire pressure gauge that's also compatible with the correct angle needed.
    https://jacosuperiorproducts.com/pro...yABEgJeAvD_BwE
    Nov 2013
    Central Texas
    This is great for adjusting tire pressure up or down. Easily adds air and bleeds air. It clips on to the valve stem so you don't have to remove it until you are done. No need for a valve extender or angled air chuck. I find that if I get my valve stem right at 5 o'clock, I can easily attach it and remove it. Also useful for tires on your cage. One of my best investments.
    https://www.amazon.com/dp/B07C25C4CQ...&sprefix=jaco+
    Northern Kalifornia
    Short of installing an accessible valve stem on the other side of the rim, you just have to overcome the struggle of airing up that rear tire the way it is by becoming creative and resourceful. Lord knows if I can do it you can do it. If I can no longer air up my tires then's the time to give up riding.
    Active Member Pooch's Avatar
    Feb 2018
    Texas Hill Country
    Quote Originally Posted by oldguyinTX View Post
    This is a great tool.
    2021 RT Ltd, Marsala Red/Black, Dark
    New course heading Mr Sulu: 2nd star to the right and straight on til morning...
    I was the first one here to move the Schrader valve to the disk side of the wheel .... The first time I did it, after the mechanic removed the rear tire from the wheel I took it home and did the drilling and adding the new angle valve .... for my other two, I just brought a battery drill & bit and did it while there in the shop. ... it took all of five minutes .... Mike
    Jan 2019
    Hunter Valley NSW Australia
    and balanced the wheel with the extender on
    2017 RTL
    2017 RTL , White
    Quote Originally Posted by askitee View Post
    From what others have reported here MOST tire shops can't balance the Rear wheel ..... However in my experience ( and others here ) the Rear wheel and tire don't NEED to balanced .... Mike
    Jun 2015
    Ritzville, Wa
    That's the one I use. I like the digital readout verse the kind with the needle type gauge.
    Greg Kamer
    "It's better to be not riding and wishing you were; than to be riding and wishing you weren't!"
    USAF, 20 years, retired
    Sadly passed away in December '23. Still helping the SpyderLovers Community, but no longer posting. Greatly Missed.
    https://www.spyderlovers.com/forums/...er-Member-here
    2018 Can Am Spyder RT-Limited
    Northern Kalifornia
    Right on Mike, the belt vibration masks the tire vibration if there is any.
    Jun 2011
    Alamogordo, NM
    Just bought one of those from Amazon, received it yesterday and wow it works great , no need for an extender, a piece of cake to use for this 80 year old.
    Thanks for the suggestion, I can do all 3 tires in no time at all. A definite 'Must Have'.
    Dean O
    Gran Pa Hoon
    Founder San Jose BMW
    Alamogordo, NM
    '20 Spyder F3 L
    Nov 2019
    Kansas
    Quote Originally Posted by old Timer View Post
    Probably wont work for me since I do not have an air compressor. I might need to get one, I guess
    2018 F3 Limited
    Feb 2022
    New Zealand
    Yep. If ya have room for it its worth its weight in the gold stuff. I dont run mine until I am doing some work requiring some air. Check the pressures and adjust if ya have to before you leave home and all sorts of other uses.
    Those snap on gauges, trigger type hookup. Yes they are great but the pressure dials are off the clock. I have one but swapped the dial out for an 0 - 60 p.s.i. Much easier to set to the lower pressures of these Spyders.
    Florida Swamp
    Yeah, you gotta have air compressor for that, but if you look around on the web or tool stores, you can find some nice, dependable, small, air compressors. They are very light weight, tankless, and run on household current. Easy to move around, very convenient, and you can get top of the line small portables for less than $100. I have 2 big shop compressors, but just for airing up a couple vehicle tires, I don't bother with dragging out all the heavy duty, stiff air hose. I just grab the small tankless and use an extension cord. For the small tires, you might want a small 12 volt that runs on the battery, to carry with you, but I am working mostly around the shop and have a small portable that plugs in 110 volt outlet, because airing up trucks, trailers, or loader tires takes a little more than the small 12 volts can handle.
    Mar 2021
    Maryland
    From what I have run into and I actually have one of the harley guys from the local harley shop to thank for this suggestion is to use a local shop that works on ATV's and side by sides and they have the equipment to balance the tires with. The shop he referred me to works on can-am side by sides so they had everything they needed to do the balance.
    But I think on the next go round I am going to give the balance bead bags a try so I can remove the weights off of the wheels. Even though the shop mounts them good the clearance between the brakes is very close (on the front) and I don't want to risk a strike on the brake if the adhesive becomes loose on the weight.
    2020 F3 SE6
    2020 F3 , Black
    Jun 2011
    Alamogordo, NM
    You definitely need an Air Compressor
    Dean O
    Gran Pa Hoon
    Alamogordo, NM
    '20 Spyder F3 L
    Feb 2022
    New Zealand
    If your not swapping tyres out on bikes you may get by with a small electric one, or an old school hand pump style for maintenance pressures.
    Danbury Connecticut
    IBA #47122
    2020 RT Limited Asphalt Grey
