Results 1 to 19 of 19
    May 2013
    Apex, N.C.
    Default Check that tire pressure!
    Gave my 2021 RTL a good once over before getting ready for the spyder rally in Maggie Valley next week. Checking the tire pressure can be a chore, but it is worth it. My fronts had 12 and 13 pounds in each. The rear only had around 18. Got that corrected and now I am ready to ride. Hope to see some of you next week.
    Apr 2020
    Edgerton,WI
    Leaving tomorrow from Wisconsin…..
    2019 F3L , Covid Blue
    Northern Kalifornia
    Guess just how many times you rode on low pressure tires. Get some tire pressure sensors. You'll know all the time what your tire pressures are.
    Dec 2020
    Hartwell, Ga
    I'll be there Wednesday morning early. Going to give mine the once over tomorrow.
    Active Member sandylolee's Avatar
    Oct 2019
    NC
    Be there Wednesday after lunch.
    2019 Rt limited chrome , Phoenix orange
    Sep 2020
    Middletown, NJ
    Good reminder with the temps getting cooler on the top of the world.
    2020 RT base , Chalk White
    Clinton, MS
    FOBO can be your friend.
    2019 RTL Phoenix Orange
    Mar 2017
    Salisbury,NC
    i just ordered FOBO2. now can check pressure with just smartphone. WOW - all in that small cap is pressure sensor, circuit board, and a bluetooth antenna!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! that is MICRO machining!!!
    Nov 2013
    Central Texas
    Quote Originally Posted by Woodaddict View Post
    Where did you get it?
    Mar 2017
    Salisbury,NC
    Quote Originally Posted by oldguyinTX View Post
    Amazon....seems to be all sellers are $148. Also Lamonster sells them too. Take your pick
    Nov 2013
    Central Texas
    Thanks!
    Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    Filled mine up yesterday. Fronts were down to 14 and the back was at 24. Added air and now she rides like a cadillac.
    2021 RT Base - Petrol Blue
    Jul 2021
    IL
    Checking the pressure in the rear tire is one of the few things I really dislike about my RT. While some may have the dexterity to do it while on their feet, I find that I have to lay flat on my back, and despite my damaged shoulders, reach the valve stem and use a tire pressure gauge. I bought the FOBO2 system not long after getting my RT, and prior to screwing on the transmitter caps of the system, I got the air pressure up to 30 in back and 20 in front. For the most part this allows me to go through the laying on my back process only once each riding season. For this year, I got the tires to the 20/30 level in April, and now here in Oct I am at 19/29 and likely fine until it is time to put the bike away for the winter. And by the way, when I have to go through the process of removing the caps and adding air each Spring, I also change the battery in each of the caps. The battery likely would last at least two years but I'd rather spend the few bucks for new batteries than risk having to again lay down on the ground midway through the riding season. I check the pressures, on my smart phone, before every ride.
    2021 Spyder RT
    2023 Royal Enfield Hunter 350
    Retired U.S. Army
    Life Member, NRA
    2021 RT , Petrol (blue)
    Active Member GreyGhost's Avatar
    Sep 2021
    North Texas
    Unless I got a faulty FOBO2 set, be aware your known pressure and what shows on your smartphone may not be the same..after making sure all tire pressures are where you want them (I do 18/28 and also replace batteries yearly) take a screen shot of the smartphone reading..this is my baseline, not the 18/28 I know them to be..
    2021 RTL Chalk White (a paler shade of grey, of which there are 50)
    Harrington, Australia
    Quote Originally Posted by GreyGhost View Post
    Where do you get your “known pressure” from, GreyGhost? Removing your inflator or pressure gauge from the tyre and then reinstalling FOBO will always let some air escape, so what you perceive as your “known pressure” probably isn’t any more, anyway.
    Hmmmmmmm…..after reading that, I don’t know that it makes any sense ….oh well.
    HeliBars Handlebars
    Kenda Kanine rear.
    Sep 2021
    North Texas
    The first few times I went back to verify when the FOBO was showing significantly less..the pressure was still within 1 psi of where it started..
    Active Member mecsw500's Avatar
    Sep 2021
    UT
    I bought one of these tire inflators off Amazon.com, It was $59 US.
    "AVID POWER Tire Inflator Portable Air Compressor, 12V DC / 120V AC Car Tire Pump, Air Mattress Pump with Inflation and Deflation Modes, Dual Powerful Motors, Digital Pressure Gauge"
    (Model ACAP322).
    I measured against a calibrated gauge and it was within 0.25 PSI under 50 psi. It does all the four normal measurement units.
    What I do is set the unit to 20 PSI and then inflate both fronts until it hits the limit and automatically shuts off. I checked the tires with a digital gauge and it was right on.
    This way I can preset the pressure and just run the thing until it matches what I did to the other side front tire. It makes balancing pressures much easier.
    I bought this one as it is 110 Volt (runs off 12 volt vehicle power too) which makes it so I don't have to worry about draining a motorcycle or Spyder battery.
    I wasn't sure about this kind of unit, but I took a plunge at that price and it seems to work really well. The inbuilt light is really useful for locating the rear wheel Schrader valve as well.
    Not something I would carry around as it is not the smallest kind of inflator available, but it works well in the garage. Inflates mattresses and sports balls as well, but I've not tried those.
    Can Am Syder RT Limited (2021)
    Triumph Bonneville T120 (2018)
    2021 RT Limited , Silver
    Oct 2021
    Wichita, KS
    I would guess you are viewing the pressure as compared to ambient temps and relative air pressure. You can turn that off in the app and it should read what the actual air pressure in the tire is.
    Peter Pan has struck again!
    Interesting, GreyGhost. After I remove my inflator and reinstall Fobo, it never differs by more than .5 psi, so my two devices must be roughly “in sync”.
    HeliBars Handlebars
    Kenda Kanine rear.
