Results 1 to 16 of 16
    Dec 2014
    S.E. Michigan
    Default Now No Reverse! Just got my Spyder back after recall OK yesterday - Ideas?
    So, finally got my Spyder back from shop for the recall. Yesterday, I went into reverse easy as you please. Today.... Not so much. In fact, not at all. And the horn won't honk either. Maybe a fuse blew? Where would I start? What fuse connects both? (If any.)
    ~Sandee~
    2016 RT-L (Purchased used in February 2018)
    RT Dash Mount (from JT's Spyder Store)
    Kuryakin Trident Highway Pegs
    Hopnel Pouch
    Magic Mirrors
    Spyderpops Foam Handgrips
    Iron Butt #35273
    Girls on Spyders #2779
    Jan 2021
    Descanso, CA
    Federal regulations require the horn to honk with ignition off. This is also true of brake lights although they are on a separate circuit. To verify circuit press the brake pedal. If the brake lights don't illuminate something weird happened. If they do check RFB F5 25A (this is most likely problem) or RFB J2 40A.
    Then call your dealer tomorrow morning.
    2014 Can-Am Spyder RT-S SE6 Freeway Commuter Pod
    2016 Royal Enfield Classic 500 Fair-Weather Mountain Bike
    Sep 2017
    Durham,Maine
    X2 on calling dealer and at least tell them they left you a mess if you can solve it and it don't happen again!! Good Luck, I hate eletrical gremlins!
    2012 RTL , Pearl
    x3. Sounds like a dealer induced glitch to me.
    Apr 2023
    FL
    The gremlin was installed free, no extra charge.
    Chip
    2020 RTL
    "Stella by Starlight"
    UltraGard Full Cover, Front & Rear Cup Holders, Elka Stage 2 Rear Shock, TC & Dave Signal Button, Spyder Extras Sway Bar
    Very Active Member Jetfixer's Avatar
    Feb 2016
    Lake Wylie, South Carolina, USA
    Look underneath from the left side. There's a bracket that hangs down about the middle of the bike. This bracket holds your reverse actuator. If the bracket looks bent, the actuator is probably damaged. They are easily bent by jacking the bike at the wrong point or by backing off of a lift that's too steep. It sounds like it could be dealer-induced damage.
    2020 RT Limited Deep Marsala Chrome
    2020 RT Limited , Marsala Red
    Dec 2014
    S.E. Michigan
    I'm fixing to go roll on the ground under my Spyder. Anything else I should look for while I'm crouched?
    If they damaged the actuator Thursday, wouldn't that have caused problems earlier?
    ~Sandee~
    Hopnel Pouch
    Magic Mirrors
    Iron Butt #35273
    Very Active Member JKMSPYDER's Avatar
    Dec 2012
    Murphy, NC
    I have had my reverse actuator switch replaced twice. There was no damage to the bracket either time. Bad luck I guess!
    2020 F3 Ltd
    Spyderpops Bumpskid
    Spyderpops Brake/Run/Turn Signal LED's
    Lamonster Garage LED Fog Lights and Headlights
    2013 ST-S retired 1/9/16 at 25,061 miles
    2015 F3S sold at 77,565 miles.
    2015 F3-S , BajaRon Plugs Can-Am Red
    Jan 2021
    Descanso, CA
    Wouldn't it be easier to check if your brake lights operate as I described above?
    And then to check RFB F5 25A ATO/ATC fuse for continuity?
    As much as I like crawling around underneath my Spyder with a flashlight with grit falling in my eyes I like standing over it more.
    There isn't any common circuit for the horn and the reverse function. If the brake lights work and the horn doesn't and F5 hasn't opened, then as suggested above the symptoms are pointing to an LHS problem as described above. I'm assuming all other Ignition-On functions work properly.
    Last edited by Peter Aawen; 09-24-2023 at 07:34 PM. Reason: Merged immediately consecutive posts...
    Dec 2014
    S.E. Michigan
    So, I tried to look under the Spyder to check the actuator. Not sure what it looks like, but I didn't see any evidence of damage. Had to cut it short, because every few minutes a car would stop and people would offer assistance to get me off the ground. Or to call an ambulance. The brake lights work well. Got dark before fuse pulling could commence. Stay tuned for tomorrow's adventure.
    ~Sandee~
    Hopnel Pouch
    Magic Mirrors
    Iron Butt #35273
    Very Active Member Isopedella's Avatar
    Feb 2022
    New Zealand
    Now that made me smile.
    I think....The actuator sits below the front pulley and lowest to the ground. Maybe a mirror may help.
    Jan 2021
    Descanso, CA
    How to check RFB F5 without opening fuse box: start your Spyder and switch-on the fog lights. If they illuminate then F5 is good and your problem is most likely the LHS as described above.
    Dec 2014
    S.E. Michigan
    So, I pulled RFB F5 25A. The fuse itself did not look blown. The contacts had a bit of corrosion (?) on them, so I replaced anyway. RFB J2 40 A looked different to me, so I stepped back and consulted you tube. I don't have a replacement for it anyhow. Tomorrow I'll pull and examine it. Got an appointment at another shop for Thursday.
    ~Sandee~
    Hopnel Pouch
    Magic Mirrors
    Iron Butt #35273
    Jan 2021
    Descanso, CA
    Question
    This is a bit worrisome. The Reverse button on the LHS is not a direct wire connection to the Console, TCM, etc but rather sends a CANBUS message when it is pressed. Isolating this possibility takes special equipment. Not expensive, just very technical.
    The construction of the LHS can be a bit fussy. The 2018 models were problematic. So we're back to diagnosing the possibility of JKM's problem
    JKM -- how did you fault isolate your switch problem?
    Dec 2012
    Murphy, NC
    I could not shift out of neutral. Both times the dealer replaced the switch. The left hand control unit was not affected.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Jan 2021
    Descanso, CA
    I'm confused. What switch?
