Results 1 to 13 of 13
    Apr 2019
    Meadville,Pa
    Default Anyone done a Cat Delete leaving stock muffler on?
    Has anyone done a cat delete with leaving the stock muffler on? I have seen people doing the delete who change the stock muffler for an aftermarket muffler, but they seem kinda loud. Not looking to drown out my radio, but just wake up the sound of the Spyder - 2022 F3 Ltd, a bit. Is it worth doing it and leaving the stock muffler? Thank you.
    Last edited by Peter Aawen; 09-13-2023 at 07:22 PM. Reason: abit; Caps; & ' 's ;-)
    Jun 2016
    indpls in
    rls cat delete stock muffler youll like it
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by fatboy View Post
    Agree 100%. Do it all the time for customers. They love it! So, unless you just like obnoxious. This is a great way to go.
    Aug 2021
    South Carolina
    I did mine a year ago and love it. I found mine had a little metallic sound, so I wrapped from the base of the exhaust manifold to the muffler with heat wrap. You can buy the wrap at any parts store.
    Oct 2015
    Lynden, WA
    I have done the stock muffler with Cat Delete on my past 2 F3Ts (2016 & 2017). Sounds great and not too loud for me.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    with all above ..... Annnnnnnnnnnnd I added the BAFFLE insert ..... plus the wrap..... Mike
    Aug 2019
    Stoughton, WI
    I did the Baldwin cat delete + OEM muffler. Sounded good.
    2022 RT Sea To Sky
    Active Member tibadoe's Avatar
    May 2013
    Gladys, VA
    The RLS was delivered last week. Will also be installing and keeping stock muffler. I believe this will be a good combo.
    Joe
    2023 F3
    Sep 2020
    Middletown, NJ
    Ditto to all above. Plus, you get the benefit of less heat from the cat and some weight reduction.
    2020 RT base , Chalk White
    Oct 2016
    Faribault, MN
    Ditto all above, I've done both RLS and Baldwin Cat deletes with stock final exhaust. And I do recommend doing the Titanium Header Heat Wrap, I did mine from the front tuned pipe and the cat delete (skipping the springs area).
    Last edited by Peter Aawen; 09-25-2023 at 05:11 AM. Reason: Fixed attach display; Caps... ;-)
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Mar 2022
    IL
    On my 2016, I had the lamonster cat delete and stock exhaust. It sounded MUCH better. I upgraded to a 2019 that came with RLS cat delete and RLS Punisher series. It is almost too loud.
    2016 F3L (sold)
    2019 F3L
    2019 F3 Limited , Position 5 brake rod Black
    Nov 2018
    Northern NV
    I just did it. Pitched the baffle that came with the pipe and used Lamonster's "Can Opener" baffle instead. Not too loud, don't notice any difference in performance but now I don't smell burning rubber when I pull into the garage and the F3 is a few pounds lighter.
    2017 F3T , Black, black and more black
    Jul 2021
    Ontario
    RLS cat delete with stock exhaust. Very nice sound.
