Results 1 to 5 of 5
    Very Active Member hypurone's Avatar
    Jun 2016
    NorCal - Northbay
    Default Urgent!! Ryder needs help near Flagstaff AZ!!!!!
    MY WINGMAN IS HAVING MULTIPLE ISSUES ON HIS 2015 F3S IN THE MIDDLE OF A TRIP TO SITO!! Sounds like a sticking brake caliper and is aslo having an overheating problem all of a sudden.... Obv the dealer there is closed til Tuesday and that would end his trip completely!!
    Anyone in the area that has mechanical abilities and tools that can help with retracting the pistons to see if that frees it up so he can continue (albeit at a reduced pace)... Might just need to clean the radiators and it only has a problem in the hotter weather....
    Last edited by Peter Aawen; 09-11-2023 at 01:10 AM. Reason: Removed ph # after post #4 - PM for contact if necessary
    Chuck
    Very Active Member cruisinTX's Avatar
    Mar 2015
    Fritch, Tx
    If you can put his location here once he is settled in a motel, I can put out a Chrome Alert on the North American Biker Rescue Facebook page. We have over 21000 member with pins on our ZEE map. As soon as I have that location to share, I will start tagging members nearest to him to see what we can do.
    Those who say " I can't" will always be right.
    2014 RT Limited , pewter (magnesium?)
    Jan 2021
    Descanso, CA
    Overheating -- I assume you've checked coolant. Are both fans operating? Which direction are they blowing? There are three fan relays in the RFB under ECM control:
    R3 Main SPST
    R5 Left Fan Reverse SPDT
    R6 Right Fan Reverse SPDT
    Sticking caliper: which one? Front pistons are easy to retract with screwdriver, clamp, etc Rear requires piston rotation as well as push to retract. If rear caliper the problem is more likely parking brake mechanism than hydraulic circuit.
    2014 Can-Am Spyder RT-S SE6 Freeway Commuter Pod
    2016 Royal Enfield Classic 500 Fair-Weather Mountain Bike
    Mar 2015
    Fritch, Tx
    I spoke with Thomas about an hour ago then got distracted and forgot to hit reply. It sounds as though he has the problem figured out but will have to wait for dealer support when they are open on Tuesday.
    Jun 2016
    NorCal - Northbay
    Thanks for those who took the time to engage with this... Yes, I got him to Flagstaff and hopefully they will work on it since they are no longer an "ON ROAD" dealer... Fingers crossed!
    Chuck
