Results 1 to 21 of 21
    Nov 2019
    Kansas
    Default Just to confirm my rear tire size and brand
    I have done some searching on here and for my 18, the best rear tire seems to be this: General Altimax RT43 215/60-15
    If that is the right one, Ill order tonight. Just wanted to confirm.
    thanks
    2018 F3 Limited
    Faribault, MN
    That's the right one
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Oct 2015
    Lynden, WA
    Thats what I have on my F3T. It's from a close out batch of tires at Tire Rack. Note the RT43 has been upgraded to an RT45.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Mar 2021
    Arizona high country
    You could also run a Altimax 225 60. That is what has been on my Spyder for the last year
    Member narygancy's Avatar
    Jul 2022
    Pennsylvania
    Quote Originally Posted by acdcking12 View Post
    thanks
    That's what I'm running on my '15 F3T. I go with 20 lbs PSI. I could be wrong but it seems to me the ride is a little stiffer than the original tire but its not a big deal. I haven't noticed a difference in handling.
    2016 S6E , Red
    Nov 2019
    Kansas
    Quote Originally Posted by Haze View Post
    I went ahead and ordered the RT45. Came to $112 Shipped
    2018 F3 Limited
    Having researched both tires. The 'Upgrade' to the 45 is minor, at best. Different tread pattern. But testing by Tire Rack (which I think is exceptional) did not find any significant differences. Both are great tires.
    Quote Originally Posted by narygancy View Post
    Any decent car tire is going to ride a bit stiffer because both the sidewall and tread area are of stronger construction. A stronger tread design keeps the entire tread section in contact with the pavement at all times. Unlike the ballooning Kendas wearing out 2.5-3" of tread in the center. The stronger sidewalls keep the tire from rolling under in hard cornering (as the Kendas will do). Which is most noticeable with the taller front tires.
    Both are significant improvements and well worth the minor downside.
    You can safely go down to 16 psi , but try 18 first ...... this will increase the comfort level ..... Mike
    Active Member Partzman23's Avatar
    Jul 2020
    Sikeston ,Missouri
    I have the Altimax (215-60-15) on the rear of my Spyder for over 20000 miles now .. I always ride 2 up and run the tire at
    18 psi. It still looks real good across the tread.
    2017 RTL Asphalt Grey Metallic Chrome
    2017 RTL , Asphalt Grey Mettalic
    Vermont
    Does the RT45 still have the "Replace tire" built/embedded with in the tire?
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Active Member ssmcclub's Avatar
    Apr 2013
    massapequa ny 11758
    When the new Kendas came out I purchased the front and back tires, they were better than the originals; now I've just installed a General RT45 215/60/15 - Wow! The ride is so much better, I will never go back to Kendas again.
    richie spyder
    Nov 2019
    Kansas
    So I finally found a guy that mounted my back car tire for me. For reference, I bought this: General Altimax RT45
    When I went to pick it up, he told me was unsure of tire pressure, and put 30PSI in it, and I bounced all the way home. So what was the correct PSI for these?
    I sent you a couple of emails dear sir.
    Last edited by Peter Aawen; 09-29-2023 at 07:38 PM. Reason: Merged immediately consecutive posts...
    2018 F3 Limited
    Jul 2020
    Sikeston ,Missouri
    Try 18 psi see if that feels better
    Feb 2020
    Minnesota,USA
    Deanna
    YES it DO!
    If in Doubt, Don't Do It!
    They may have been blocked by my server ..... send me a PM on this forum ..... Mike
    Nov 2019
    Kansas
    I got your answers. Thank you sir
    2018 F3 Limited
    Vermont
    Quote Originally Posted by Knizar View Post
    YES it DO!
    Knizar,
    Thanks for the info.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Very Active Member Bangorbob's Avatar
    Jun 2018
    Pahrump NV
    Are these the same tires for a 2020 RTL?
    2005 Roadtrek Chevy 210P
    2020 RT Limited-Chalk White SE6
    Quote Originally Posted by Bangorbob View Post
    The only differences in tire sizes for all models & so far, all years of Spyders is that the pre-2013 models ran 14" front wheels - they went to 15" rims up front in 2013 to fit the Brembo brakes. So anything from 2013 & on will be running the same size 15" rims and pretty much the same few sizes of tires that will fit. Unless of course, someone's done some extensive mods.
    So apart from the obvious differences between OEM & A/mkt tires, the answer to your question is YES!
    Active Member RudyB's Avatar
    May 2016
    Abbotsford British Columbia Canada
    thanks
    Yes you can’t go wrong
    Jun 2018
    Pahrump NV
    Thanks. Will be ordering soon.
