Results 1 to 15 of 15
    Apr 2023
    Fargo ND
    Default Is it normal for 2011 RT to have very touchy steering at speed?
    Just checking, since we have had this running and on the road for under a week.
    At highway speeds, the steering seems very touchy. Is that normal? is there an adjustment to this?
    Dave Muir
    Fargo, ND
    2014 Harley Ultra Limited
    2011 Spyder RT SM5
    Feb 2012
    Spring City,Utah
    Have you ridden other Spyders? Try relaxing your grip and your arms. The Spyder steering can be "touchy" but mostly needs less input from you so lighten up on the grips. BTW whart was wrong that you have only had it running a week?
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    .... if this is your First Spyder, it's not an un-common complaint..... I like to use the term " GUIDED ". when I explain how I steer my Spyder. I've driven my 14 RT at well over 100 MPH, with barely touching the handlebars ( NEVER DO THAT ) .....however if you've owned Sp[yders for years then something might be mis-aligned .... good luck .... Mike
    Quote Originally Posted by Dmmuir View Post
    I will simply echo what others have said. If you are new to the Sypder, this is a universal complaint. Especially if you are coming off of 2 wheels. The key is to Relax, Relax, Relax. But having said this, there are things which can magnify what you describe as 'Touchy'. Front tire pressures over 20 psi. Out of alignment (check front tire wear for this). But chances are, it's nothing more than the learning curve that takes between 500 - 1,000 miles of riding to overcome.
    The more miles you ride in the shortest amount of time will tend to reduce the time it takes to get comfortable. Hang in there and you'll be fine.
    Durham,Maine
    x4
    2012 RTL , Pearl
    Active Member Pooch's Avatar
    Feb 2018
    Texas Hill Country
    I found that setting the front tire pressures, when cold, at 18psi solved the problem for me. Otherwise, it felt like a beachball bouncing all over the place.
    Also lowered the new rear tire to 25 psi.
    2021 RT Ltd, Marsala Red/Black, Dark
    New course heading Mr Sulu: 2nd star to the right and straight on til morning...
    Apr 2023
    Fargo ND
    I bought this for my wife, who has never ridden. I am used to a 2 wheel bagger so it's totally different. but I have to admit this is a really fun machine to ride.
    I also need to reduce tire pressures by a bit.
    As to why it's only on the road now, i bought this from an acquaintance with the DPS system out and an overheating problem. I replaced all this and went through the whole bike. Now that it is rideable I need to teach the wife.
    Sounds like front tires should be at 18 psi and rear around 25?
    I have them all set at around 30..... oops
    Dave Muir
    Fargo, ND
    2011 Spyder RT SM5
    Hi, as far as PSI goes will be different depending on what BRAND tires you have ... OEM Kenda's front 17 psi +/- one ....rear 28 +/- one. I switched to Auto tires more than a decade ago and love them I use Front 16 psi Rear 18 psi ..... trust me this what works with any auto tires .....PS your wife will have an easier time learning because She never drove a two wheeler .... best advice I got was just drive it like a CAR - foot brake only +++ steer gently ..... and take Her to safe area ( like a parking lot ) and have Her do some quick STOPS ... She needs to know how good the Brakes are ..... keep us posted .... Mike
    Dec 2020
    Hartwell, Ga
    Yep, way too much air in the tires.
    Also, what kind/brand of tires are you running? If you are running the Kendas then 18 front and 24-25 rear, if you are running car tires all the way around then it should be 17-18 psi for all three tires.
    It looks like Blueknight & I was thinking the same thing at the same time. lol
    Apr 2023
    Fargo ND
    That is the plan. She has to learn a manual transmission as part of this as well. I do have Kenda's on it, so I will drop that air pressure and see how she rides.
    Dave Muir
    Fargo, ND
    2011 Spyder RT SM5
    First of all, let me say
    The issue you mention is a very common one for those that are new to the Spyder. So much so, that we have even given it a name. Most of the others have already made mention of this.
    A lot of us refer to the cause of the problem as the "death grip." The Spyder is VERY responsive to ALL inputs. That can lead to the "twitchiness."
    I used to say...pretend that in your hands around the handgrips are EGGS. Do NOT grab so hard that you break the eggs. A gentle push/pull on the bars is all it takes. Most find that the problem quickly goes away as you become more accustomed to the Spyder idiosyncrasies. We used to say there was about a 500 mile learning curve. I guess I am not so smart. It took me about 1500 miles to get comfortable with my first Spyder. I had the first one sold to a customer back in Alaska in 2008.
    Mar 2021
    Haven, Ks
    I haven't ridden your bike so I will not endeavor to tell you how to ride it. I will say that I moved to a 2019 Spyder RTL after 60 years of riding 2 wheels. I hated it for the same reason you described. Thought the bike was twitchy and couldn't stand it. Installed a Baja Ron Sway bar, had the bike laser aligned and balanced the inflation on the tires to 18 lbs on front and 26 on back(OEM tires) I won't presume to tell you how to ride, how to grip your bars an anything else. I will, however, bet that if you balance the tire inflation as described and get the bike aligned and install a sway bar that you will absolutely love it. I do and wouldn't go back to two wheels for anything. In fact you can see from my sig line that I liked it so much I traded for a 2022 Sea to Sky. I would comment that the difference between 19lbs and 20lbs is unbelievable.
    Bartender
    2022 Spyder Sea to Sky
    Active Member helton61's Avatar
    Jan 2023
    Virginia
    Adjust air pressure and ride it about 1000 miles you will love it.
    Apr 2023
    Fargo ND
    I made the air pressure adjustment this morning and rode it to work. Major improvement. Now I would call it very responsive, it's a much better ride this way.
    I didn't realize how much fun one of these can actually be!
    Dave Muir
    Fargo, ND
    2011 Spyder RT SM5
    The Spyder is very tire pressure and alignment sensitive. Tires can also make a big difference. I am glad you are making progress. Hang in there and it will pay off!
