Results 1 to 7 of 7
    Jul 2023
    Ontario
    Default Any options for giving passenger a backrest and armrests?
    Hi folks!
    Getting a 2020 Spyder RT on Wednesday, first time back on wheels in about 30 years. It's the base model so doesn't have the back and armrests for the passenger. Do I have any options to get an OEM or aftermarket parts? I'm also missing the rear luggage case, which I assume I can order from BRP.
    Thanks in advance!
    2020 RT , Grey
    Jul 2023
    S.E. Pennsylvania
    In Can Am's accesory catalog it looks like the back rests and arm rests are available but it looks like you also need order the rear rack. Consult your dealers parts department.
    https://can-am-shop.brp.com/on-road/..._vehicle=10842
    Lee B
    2022 Can Am RT Limited
    2021 Honda NC750X DCT
    Dec 2020
    Hartwell, Ga
    As stated, parts are available.
    On the arm rests, they are an accessory item that is available in both OEM and aftermarket.
    IMHO the OEM looks better but if you have a plus size wife, they may not work out for her as they will not swing all the way out to give access for easy mounting and dismounting. For this reason, I do not have them, and my wife is happy without them.
    Adding the OEM trunk will get expensive really quick. I have saw a couple of used ones online, but they are around the 1000.00 - 1500.00 range. Someone on here did install an aftermarket one with a backrest but I can't recall his name.
    Sep 2020
    Middletown, NJ
    I bought the rear rack and bolted a Shad Base Plate to the rack. I cut a hole in the plate to access the LinQ knob.
    Total cost for rack & topcase was under $700.
    2020 RT base , Chalk White
    Quote Originally Posted by Canadanewsman View Post
    Hi folks!
    Thanks in advance!
    Go to the Utopia website, they make for the Operator .... I would contact them and ask ..... good luck .... Mike
    Active Member GS1's Avatar
    Sep 2014
    New Jersey
    I got the rack and the back rest on mine works great when she wants to ride and quick change when she doesn't
    Improvise, Adapt, Overcome, Semper Fi
    2020 RT
    Limited heated seats
    removable back rest & rack
    XK Glow light
    Paint with light painted panels
    (Gone but not forgotten ) 2009 RS SE5
    2020 RT , Chalk White
    Looks like they have all given good information.
Tags for this Thread
