2023 F3-T Limp home mode/check engine light- any ideas?
Hey everyone, I washed my Spyder this morning, no high pressure, was riding home, tried to set the cruise while going about 25 and the bike immediately went into limp mode and check engine light is flashing. I rode home with no issues, was installing a new horn, so the battery was disconnected for a couple of hours. Started the bike up, no check engine, started riding, went about a 1/4 mile and it went back into limp mode. I plan on setting up an appointment, but figured I would see if anyone had any suggestions. I have approximately 1700 miles. Thanks
Okay, so I checked my Pedal Commander and even though it is in the water resistant cover, there was quite a bit of moisture inside the cover. I disconnected the battery and the PC, hooked everything back up stock and everything is back to normal.
It's always good to hear what the solutions are to problems. Thanks!
Glad, you found the problem, and got it resolved quick.
Where did you have the PC mounted?
Retired U.S. Coast Guard 76-97
Shad bags
Lamonsters 2.0 usb dual power plate
F3 ultimate boards
LED arc lights
Lidlox helmet extender
Lamonsters top cuff with Ram ball and phone holder.
Lamonster billet sway bar end links
BRP driver backrest
LED Volt meter
BIW Cat Delete pipe
Route 129 windscreen
It was mounted on the inside of the side cover, but the adhesive didn’t hold and it was dangling right above the bottom of the cover.
Shad bags
F3 ultimate boards
LED arc lights
BRP driver backrest
LED Volt meter
BIW Cat Delete pipe
