Where is the ECU on a 2008 Spyder GS? Any hints on how to remove it?
Does anyone know where the ECU is located on this model and how to remove it? Thanks
Reason: Expanded title to briefly ask the question... ;-)
At the end of the big Engine harness, below the dash console I think.
https://www.ktmhobart.com.au/partFin...e-harness#next
The best substitute for brains & knowledge is....................silence.
Update, found the ECU and it was under the dash console as mentioned by Freddy. Thanks for the suggestion, spent hours looking for it. Disconnection was pretty easy. Two bolts and two clips for the wiring. Sent it off to jediperformance.com for a stage 1 flash. Hope everything goes well and I get it back asap.
Please keep us posted on what you achieved ....Also supply info on cost etc. thanks . Mike
