Results 1 to 12 of 12
    Active Member Pikester's Avatar
    Rio Rancho, NM
    Default Is the High pitched whine after shut down normal?
    Not sure if this is normal, but after I shut everything off on my 23 F3-T, there is a high pitched whine. Anyone else experienced this?
    Last edited by Peter Aawen; 07-14-2023 at 12:41 AM. Reason: Expanded title to briefly ask the question... ;-)
    2023 F3-T , Petrol Metallic
    Quote Originally Posted by Pikester View Post
    After you shut the engine down the system re-boots.... Mine makes the sound also ....Mike
    Rio Rancho, NM
    Thanks Mike!
    Yes, it is normal. The ECU keeps the throttle body slightly closed after shutdown. Since it is a 'Fly-by-Wire' system (electric motor actuates the throttle body butterflies). What you hear is that motor whine. I don't remember the time interval. But it does time out after a bit and the whine goes away.
    On the early Spyders, it's something like 30-40 minutes... Not sure it's quite so long on the later Spyders tho?!
    Last edited by Peter Aawen; 07-15-2023 at 07:40 PM. Reason: Fixed quote display ;-)
    Rio Rancho, NM
    I wonder if it is some sort of calibration procedure?
    I misspoke on post #4. The throttle body servo holds the butterflies CLOSED, not open. (edited & fixed)
    I believe the startup default setting is 8 degrees open. Which previous, cable controlled Spyders used. The reason BRP did this with all Fly-by-Wire models, I've been told, is that leaving the throttle body open allowed residual fuel vapors to migrate creating a possible explosive mixture. Supposedly, there was a possibility of Run-On or even fire, in extreme cases.
    I can't verify the 2nd answer, but the Closed vs Open, that is for sure.
    Rio Rancho, NM
    So, my Spyder has been sitting in the garage for 1 hour and 15 minutes, and it’s still making the whining noise.
    Feb 2020
    N. Wilkesboro, NC
    I never owned an F3 but I'd hear a high pitched whine every time I'd shut down either of my RTs. Turns out the whine was coming from me.
    2021 Honda HRV
    2245 Constitution class starship (refitted 2270-2271) (for sale)
    2021 Can Am Spyder RT (gone)
    2019 Honda CR-V (gone)
    2018 Can Am Spyder RT Limited (gone)
    2014 Kawasaki Nomad (gone)
    Rio Rancho, NM
    Quote Originally Posted by MONK View Post
    Monk, was the whine because you had to stop riding????
    Rio Rancho, NM
    So, the noise I was hearing was the gas tank venting. Another member suggested I check that, and it immediately stopped when I opened the cap.
    Durham,Maine
    I was going to suggest that. No really!!!!! Glad you have it figured out.
    2012 RTL , Pearl
