Results 1 to 8 of 8
    Member Jerry226's Avatar
    Jun 2023
    Indiana
    Default What antifreeze can I use besides Can Am's?
    what antifreeze can you buy besides Can Am? I need some and I am 35 miles 1 way to my shop? Thanks
    Last edited by Peter Aawen; 07-07-2023 at 06:46 PM. Reason: Expanded title to briefly ask the question... ;-)
    2013 RT Limited , stock bronze
    Quote Originally Posted by Jerry226 View Post
    Well, it depends on what year your Spyder is .... I believe BRP used two types ..... Green for V-twin engine Spyders .... and orange for the 1330 engine Spyders. Neither has to be BRP brand .... I use orange DEX-COOL, by Prestone .... I buy the concentrate and mix it 50/50 with distilled water .... the Pre-mix version costs more ..... PS, I added a pint to the OEM stuff already in the radiator .... 5000 mi. later it's working fine, so it is compatible .... good luck .... Mike
    Last edited by Peter Aawen; 07-07-2023 at 06:48 PM. Reason: Fixed quote display ;-)
    Active Member T.P.'s Avatar
    APPLE VALLEY, MN
    I use Peak Global 50/50 Lifetime in everything.
    T.P.
    Dec 2022
    NY
    I use Prestone’s all makes all models 50/50 premix. It’s compatible with everything. As per BajaRon, as long as it says it’s safe for aluminum engines, you’ll be fine.
    ~~2010 RS SE5 My first Spidey, but not my first ride~~
    The trigger’s been pulled. We have to
    get there before the hammer falls.
    Bossier LoUiSiAna
    what ever brand just use same color. Flush/rinse & new every 2yr
    Aug 2012
    Central Coast, CA
    Just be aware that now-a-days color can be irrelevant. Anti-freeze comes in a whole variety of colors, red, blue, orange, green, yellow, etc. You have to know whether it's a HOAT type coolant or not. Topping off with a universal application type coolant works just fine.
    2020 RTL SE6
    Feb 2022
    New Zealand
    Some info on the aforementioned HOAT coolant.
    https://knowhow.napaonline.com/what-...-need-to-know/
    2017 F3 Ltd
    Quote Originally Posted by Isopedella View Post
    Thanks for that LINK .... IT was what I knew, but was well written .... Everyone should read it ....takes about 5 min. .....Mike
