Replaced rear turn & back up lights with LED's, now blinking fast! Fixes?
I decided to replace my incandescent bulbs (rear turn signals and back up bulbs) with led for brighter awareness. Now my turn signals blink fast so I would like to ask for advice about how to correct this issue please..? Thanks
2016 RT-Ltd
Bajaron swaybar
Spyderpops trunk light
Elka stage 2 front shocks
Extra longbrake pedal
brake modulator
Rivco dual flag holder
with American and Texas flags
Lamonster Magic Mirrors
missing belt guard
Lamonster led fog lights
Baker air wings
2019 Silverado Duramax dually
2019 Cyclone 4007 toyhauler
Rivco brand footrest
spydermanexhaust.com exhaust
You need either an Led turn signal flasher OR resistors. Don't ask how I know. The sellers very rarely if all explain this.
2005 Roadtrek Chevy 210P
2020 RT Limited-Chalk White SE6
Had the same problem with my Honda Pioneer 1000. I replaced the stock flasher relay for this one, and it works great. Not sure about Can Am
Retired U.S. Coast Guard 76-97
Shad bags
Lamonsters 2.0 usb dual power plate
F3 ultimate boards
LED arc lights
Lidlox helmet extender
Lamonsters top cuff with Ram ball and phone holder.
Lamonster billet sway bar end links
BRP driver backrest
LED Volt meter
BIW Cat Delete pipe
Route 129 windscreen/ some time's
Pedal Box Pro
Spyderpops A- Arm LED Lights
OR you could just leave them flashing faster ..... they are actually More noticeable doing the Hyper Flash thing.... You said want to be More noticeable .... well you will be .... Mike
I did the reset and sometimes they flash correctly and sometimes they flash faster. I don't really care as long as they flash.
Try replacing the LED's with new LED's from Auxito. Theirs come with load resistors built into the bulbs so you don't have to modify the wiring on your Spyder. I used them on my 21 RTL and it was plug and play with no hyper flash.
2021 Spyder RTL chalk/black/chrome bought in March 21. Previous rides: 2019 Spyder RTL, Orange/chrome. 2015 Harley Heritage, 2002 Harley Heritage, 77 Harley Electra Glide, 75 Harley Electra Glide, 72 Harley Sportster (first bike bought new)
My Spyder Mods
Rider backrest, F&R cup holders; F3 handlebars; BRP LED driving light; LaMonster front fender and mirror turn signals, LaMonster Saddlebag lights, Auxito LED rear turn signal blubs w/ built in load resistor; Brake lite modulator/flasher; LaMonster flags on trunk; Garmin Zumo XT. LaMonster Bluetooth adapter for Phone & GPS through Spyder speakers. LaMonster floorboard risers; FOBO tire pressure monitors, Vredestein front and rear tires; BajaRon sway bar.
Would you please provide a part number or some reference. Not all Auxito come with resistors.
We bought a couple pairs for our RT's, so far so good. Unfortunately they are discontinued, this is a link for the replacement, they are a bit shorter and will most likely cause less issues with continued use (emergency lights) with the bezel due to heat. I'm sure they'll be more than bright enough!
new part:
https://www.amazon.com/LIGHSTA-BAU15...09JW4THLT&th=1
Originally Posted by Dasmoetorhead
The Spyder does not use a flasher. Flashing is controlled by the firmware in the cluster.
Thanks for clarifying this subject.
I went to their web site but they didn't have a listing for Can Ams
Greg Kamer
USAF, 20 years, retired
2018 Can Am Spyder RT-Limited
This looks like the replacement bulb https://www.auxito.com/collections/7.../7507-led-bulb. How easy is it to get to those bulbs? I would prefer all LED lights myself. Thanks!
2022 Spyder RT SEA-TO-SKY Mystery Blue... (bought new May 2023, a work in progress...)
2015 Can-Am Red F3-S, SE6
CalSci shield, Elka stage 5 rear shock, stage 4 front shocks, Akrapovic silencer, BajaRon Bar, Roadster Renovations vibration dampener, Tricled LED headlights and auxiliary lights, driver floorboard, driver and passenger backrests, Tricled Safety Led package, Shad BRP/SH36 side cases, Baker built luggage rack, Tricled Rear run/brake/turn signal led, Tricled LED piezo brake bullet strobe, JDM Astar LED bulbs for rear and front lights, Airhawk seat pad, USB power outlet
Originally Posted by RPM
Thanks, I book marked the link.
Greg Kamer
I'm reluctant to give a part number because the OP has a 16 RT and I bought bulbs for my 21RTL. I don't know if both bikes use the same bulbs, I do know that the bulbs for my 21 have an unusual offset pin arrangement on the base. The pins that hold the bulb in the socket are NOT 180 degrees apart, but are 150 degrees. As far as the load resistors, their website is very specific about which bulbs have resistors, the color of the LED, voltage and wattage etc. If you have more questions you'd be better served to call Auxito,
My Spyder Mods
LED's don't create enough load to flash slow ..... it's like in your car if 1 bulb (say the front corner goes out).... the rear corner on same side will brink fast because it only has half the load on it. But if you can put a resistor of the same load in the pos. side of the wire connector, then it will blink same speed as it did the regular bulb in it.
Reason: Caps & ' 's ;-)
Here's your turn signal solution https://www.spyderlovers.com/forums/...=1#post1646924 (read the entire thread).
As I note later in the thread, returning to flash rate to normal is tricky and you are unlikely to get it right the first time. The most difficult part is detecting the console symbols flash indicating the next step in the process.
In my experience the flash rate is normal unless you are at a stop for a minute or so in which case the flash rate doubles. It doesn't return to normal until you start moving again.
Forum
RT Shop Talk
