Results 1 to 9 of 9
    Jan 2023
    Virginia
    Default Need a replacement Fog Light switch - anyone else? What did you get?
    I have a 2013 RT Limited and my fog light switch has gone bad, and a replacement isn't available through BRP. Has anyone else experienced this and what was your solution?
    Last edited by Peter Aawen; 06-22-2023 at 06:58 PM. Reason: Expanded title to briefly ask the question/s... ;-)
    Apr 2023
    FL
    Suggestion: Read the switch and Google any names or numbers you see. Somebody made that switch and it wasn't Can Am. Some electrical outfit that makes switches by the million.
    Chip
    2020 RTL
    "Stella by Starlight"
    UltraGard Full Cover, Front & Rear Cup Holders, Elka Stage 2 Rear Shock, TC & Dave Signal Button, Spyder Extras Sway Bar
    Nov 2015
    Chardon, OH
    Quote Originally Posted by mikext View Post
    I have a 2013 RT Limited and my fog light switch has gone bad and a replacement isn't available through BRP. Has anyone else experienced this and what was your solution?
    First, are you checking the lights with the engine running?
    Yeah. The switch was part of the optional Fog Light kit and not in the parts system as a separate spare part. However, it DOES have a part number.
    710002351
    There's a few out there. For example...
    https://www.ebay.com/p/4023695320
    Doug
    ”Freedom is not a loophole”
    Very Active Member SLICE's Avatar
    Aug 2022
    manatee county Florida
    Amazon has rocker switches for $9-
    Apr 2022
    Oklahoma
    The fog light kit supplier may also sell the switch. Never hurts to call.
    Very Active Member campermac's Avatar
    May 2015
    Etters PA
    I have been using these guys for years for multiple machines, boats, snowmobiles, ATV's, SxS and now Spyders.
    https://www.otrattw.net/
    Send them an email or call them, they will make you anything you want
    2022 RT Limited , Silver w/ Black and Purple accents
    May 2020
    E. Central Illinois
    Don't know about the older Spyders, but the switches on the newer ones (I have a '20) are made by Carling.
    Idaho
    I bought a Carling switch when I added driving lights on the 2013 RT I had. The light and symbol may not have been the same as the OEM, but why would one care about that on a 10 year old machine?
    2014 Copper RTS
    Active Member tntnj's Avatar
    Sep 2015
    JerseyShore
    Make sure the switch is 44mm long not 37mm if you are installing it in the with the factory switches. most switches were wide enough (22mm) but were too short and not able to lock in the opening
    2017 F3 LTD (SOLD)
    2017 HD Freewheeler (SOLD)
    2021 RT Base Upper and lower adjustable deflectors , Top case, Signature and lower lights, Baja Ron Bar, Back rest,Fobo TPMS, Garmin 396 , LED Fender lights, Rear LED turn and brake lights, Rear Brake light flasher, Rear Saddle bag LED lights, Battery tender, Lamonster Handle Bar Riser.
