Results 1 to 25 of 26
    Active Member Dasmoetorhead's Avatar
    Jun 2023
    Tennessee
    Default Which motorcycle lift?
    What's everybody using for a lift? I'm going to need one. I've been looking at Pitbull, and L&S. I watched a review on the harbor freight lift, and it basically said it was unstable. I used to have a Craftsman to service my Kawi Nomad 1600, and it worked OK. Not sure how it would work on my F3.
    Retired U.S. Coast Guard 76-97
    Shad bags
    Lamonsters 2.0 usb dual power plate
    F3 ultimate boards
    LED arc lights
    Lidlox helmet extender
    Lamonsters top cuff with Ram ball and phone holder.
    Lamonster billet sway bar end links
    BRP driver backrest
    LED Volt meter
    BIW Cat Delete pipe
    Route 129 windscreen
    2022 F3S , Monolith black
    Feb 2012
    Spring City,Utah
    Since the craftsman is almost the same as the HF it should work fine. I have the HF bought in 2008 and it works good. I do have to run the Spyder up on 2x4s to get it underneath. I also use a regular floor jack and ramps.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Jun 2023
    Tennessee
    Thanks for the info. I never had a problem with that Craftsman. I know I need one.
    Shad bags
    F3 ultimate boards
    LED arc lights
    BRP driver backrest
    LED Volt meter
    BIW Cat Delete pipe
    Sep 2020
    Middletown, NJ
    This HF lift has been very good for 3 yrs so far. It is as stable as one would expect sitting on a one sq ft platform.
    https://www.harborfreight.com/1500-l...torcycle+lifts
    2020 RT base , Chalk White
    Jun 2023
    Tennessee
    Quote Originally Posted by RayBJ View Post
    This HF lift has been very good for 3 yrs so far. It is as stable as one would expect sitting on a sq ft platform.
    Thanks, that's good info. I was actually considering this same lift.
    Last edited by Peter Aawen; 06-16-2023 at 01:52 PM. Reason: Fixed quote display ;-)
    Shad bags
    F3 ultimate boards
    LED arc lights
    BRP driver backrest
    LED Volt meter
    BIW Cat Delete pipe
    Bossier LoUiSiAna
    have done similar depending on the maintenance, have also just used ramps for front (tires strapped down) & floor jack on swing arm allows more available space for catch pan.
    ** (comparing rims, but shows the strap locking it in place)
    Last edited by Peter Aawen; 06-16-2023 at 01:54 PM. Reason: Fixed attach display ;-)
    Jun 2023
    Tennessee
    I'll add ramps to my list.
    Shad bags
    F3 ultimate boards
    LED arc lights
    BRP driver backrest
    LED Volt meter
    BIW Cat Delete pipe
    Active Member NorwegianRT's Avatar
    Apr 2022
    Southern Norway
    I have been very happy with my "Easy Rizer" from BigBlue UK
    It should also fit F3s !
    Brgds Martin
    Jun 2023
    Tennessee
    No doubt the Big Blue is nice. A bit spendy, although I do like it.
    Shad bags
    F3 ultimate boards
    LED arc lights
    BRP driver backrest
    LED Volt meter
    BIW Cat Delete pipe
    Durham,Maine
    What is it your working on? I find that for the most part I am working on ether the back or front and just a low level floor jack underneath in the right place works well! heck if you get it in the right place you can pick the whole bike off the floor, but it's not very stable and you would need jackstands if you were going to wrench on it!
    2012 RTL , Pearl
    Jun 2023
    Tennessee
    I'll be working on a 2022 F3-S. I'll use it for wrenching and cleaning.
    Shad bags
    F3 ultimate boards
    LED arc lights
    BRP driver backrest
    LED Volt meter
    BIW Cat Delete pipe
    Feb 2022
    New Zealand
    Quote Originally Posted by Dasmoetorhead View Post
    It will work real well.
    I use something like this.
    We call theses an ATV lift locally.
    But they are all basically the same.
    Provided you..
    Place some supports near each of the wheels.
    I use axle stands for the front a arms. You could use blocks of wood or something.
    And some blocks under the rear tyre.
    Stops it swaying and solid as a rock.
    Ramps are great as well.
    2017 F3 Ltd
    Jan 2019
    Hunter Valley NSW Australia
    I have the Big Blue, and while it was a few $$$$ my back, knees and other parts of my body are very happy I bought it. It can lift my RTL high enough to avoid having to bend down for hours on end and is easy to operate. I did have an ATV lift but you are pushing your luck keeping it stable in my opinion - there are some jobs I just would not do on the ATV lift.
    2017 RTL
    2017 RTL , White
    Jun 2023
    Tennessee
    Appreciate all the information. I guess my 2 small floor Jack's and jack stands will work for routine maintenance for now.
    Shad bags
    F3 ultimate boards
    LED arc lights
    BRP driver backrest
    LED Volt meter
    BIW Cat Delete pipe
    Jun 2022
    N.E. Fl
    Bought a Pitbull lift in 1994, it sees alot of use
    2016 F3-T , Blk/Rd
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Isopedella View Post
    Provided you..
    most consumer jacks are good enough for lifting the bike high enough to be able put stable support under it before working on it. I use a combination of jack stands, screw jacks and/or RV leveling blocks.
    2014 RTL Platinum
    Jun 2023
    Tennessee
    Ya, thanks. For now that's what I'll end up doing. I guess the bike has to be in the shop 1st. I was supposed to be picking it up today, but now it looks like Wednesday. That'll be 3 weeks, since I paid for it. I'm bummed about not having yet. I'm ready to go.
    Shad bags
    F3 ultimate boards
    LED arc lights
    BRP driver backrest
    LED Volt meter
    BIW Cat Delete pipe
    Active Member Rednaxs60's Avatar
    Mar 2021
    British Columbia
    Use the Big Blue Lift for Spyder and Gold Wing. Gets the bike some 25 inches off the ground. Also use a CAT 4500 lb scissor lift. Went with this because the ATV scissor jacks don't like to lift my AWD Hyundai.
    "When Writing the Story of Your Life, Don’t Let Anyone Else Hold the Pen"
    "Too many of us are not living our dreams because we are living our fears.” – Les Brown
    2014 Can-Am Spyder RT LE
    1985 Honda GL1200 Goldwing Limited Edition
    Ernest
    Jun 2023
    Tennessee
    I sure do like that big blue stand. I'm a shop rat, and I know I'll be tinkering on the Spyder and keeping it maintained. I'm sure I'd get my money's worth from it, but dang they're expensive. The new Spyder will probably be my last bike. I'm 66 now, and hopefully this new F3 will be the one I keep. 2 wheels are out now. I enjoy being in the shop with some good tunes maintaining my machines. Thanks for your input.
    Shad bags
    F3 ultimate boards
    LED arc lights
    BRP driver backrest
    LED Volt meter
    BIW Cat Delete pipe
    Nov 2018
    Northern NV
    I have a Craftsman, no trouble lifting my F3T
    2017 F3T , Black, black and more black
    Active Member Woodenfish's Avatar
    Feb 2022
    Illinois
    I have a Craftsman motorcycle jack that I use on my RTL’s. It will lift it but you have to be very careful with its balance on the jack. You can lift it up fine but if you have to take the front tires off you better have the bike supported with 3 jack stands. These style of lifts aren’t really ideal for the Spyder for all maintenance. The 1500 pound lift capacity is overrated for its hydraulic cylinder actual power which can lead to a shorter than expected service life. I haven’t found any lift that is ideal and affordable to lift these heavy bikes with solid stability so be careful, go slowly and constantly check for balance. Lifting these 3-wheelers is dodgy and a great amount of care is required when working on a lifted Spyder to prevent the whole bike from tipping off the jack. These lifts raise the bike at an upward angle toward you and not true vertical so lowering it onto the jackstands has to be done with great care as the bike is lowered away from you. I’m a professional automotive technician with decades of experience but lifting these Spyders always gives me the heebee jeebees.
    2021 Spyder RT Limited Asphalt Gray Chrome Edition
    2022 Spyder RT Limited Hyper Silver Chrome Edition
    Spyderco Paramilitary 2
    Vanquest Gen 2 7x10 First Aid Trauma Pack
    Garage Door Opener
    iPass
    DJI Action 2
    Tackform Anti-Vibe Phone Cradle
    UltraGard Full Covers
    Show Chrome rear trunk lid lift strut
    Noco Genius 1
    Noco GBX Booster X
    Show Chrome Platinum Grande Adjustable Padded Driver Backrest with Storage Pouch
    Baseus Cordless Inflator
    Jun 2023
    Tennessee
    Thanks for your evaluation. Yes I totally understand. When I used to lift my Nomad 1600 with the craftsman jack, I had to be careful (as you should), and there were some wobbly moments. The big blue is probably the answer, and it might find its way in my shop, because I know how often I will use it. I'm also not fond of balancing anything heavy like a F3 on a small platform. Trying to stabilize a machine in the event it gets out of hand is not in the cards anymore with my back in its current situation. I'm just going to wait to get the machine in my shop and then evaluate what I think is best.
    Shad bags
    F3 ultimate boards
    LED arc lights
    BRP driver backrest
    LED Volt meter
    BIW Cat Delete pipe
    Jun 2023
    Tennessee
    I called Big Blue Co. about their lift, and he said they don't have the new F3S mount yet. So that's out for now.
    Shad bags
    F3 ultimate boards
    LED arc lights
    BRP driver backrest
    LED Volt meter
    BIW Cat Delete pipe
    Apr 2022
    Southern Norway
    Bad luck there then !
    I thought they did due to this line on their site :CanAm Spyder RT/F3T/S Trike Lift
    Have a great weekend and ride safely !
    Brgds Martin
    Jun 2023
    Tennessee
    This from the company,
    The lift would come with the F3 mount set and the main lifting items that locate on the lift beam fits all models of Spyder it is simply the adjustable stabiliser bracket that is located near the pillar to hold the machine from moving left to right as it balances on the lifting points.
    The latest F3S has a different mount required at this point (see the picture) and as yet we have been unable to acquire a Spyder to develop the bracket needed so the only option at this point in time is to use this setup and secure the Footboard mounting to the lift by means of a ratchet strap as this does ”Not” take and load in the lifting it is simply to hold the machine from rocking sideways, “A Stabiliser”!
    Hopefully we will get to develop the part at some stage but cannot offer it at the moment.
    Regards
    Shad bags
    F3 ultimate boards
    LED arc lights
    BRP driver backrest
    LED Volt meter
    BIW Cat Delete pipe
