Results 1 to 20 of 20
    Jun 2015
    Ritzville, Wa
    Default The physics of bugs
    OK, I understand completely how bugs manage to get themselves squished on the outside of my windshield. What baffles me is how they manage to get themselves squished on the inside of my windshield.
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Dec 2020
    Hartwell, Ga
    Maybe you're going the wrong way?
    Just kidding as I don't have a clue.
    Sep 2015
    Chilliwack, BC. Canada
    Quote Originally Posted by gkamer View Post
    Just letting you know Greg, you’re not alone with this problem!
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Dec 2013
    Not that I see it all that often now I don't wear my Dress Uniform so much, but if you ever ride your Spyder while wearing a tie that's slipped its pin so there's no longer anything to restrain it/stop it flapping in the breeze, things might become a whole lot clearer!
    It's quite an odd feeling to be riding along feeling the breeze blowing strongly into your face but having your tie stick out horizontally forward in front of you, with only the very tip madly flapping just behind the windscreen; but my RT with its big windscreen is not the first bike I've experienced this on!
    Apparently, it's all to do with the way the windscreen forces the air to flow out & around it & you in the 'Rider/passenger bubble' behind it, but it creates a really strong low-pressure area in the gap immediately behind the screen and in front of you. Any bugs travelling toward you that aren't immediately ahead (so that they end up as smoosh on the front of the windscreen! ) can get forced out & around the windscreen, only if they are travelling toward you at the right speed and close enough to the edge of the screen, they can be sucked into that low pressure area behind it & ahead of you, and end up being slammed into the back-side of the screen at high enough velocity to splatter; while those travelling juuust a little further away &/or not approaching at the same speed &/or angle just get pushed away as the windscreen forces its way thru that dirty great wall of air it hasta move thru!
    Innnnterrrresting, innit?!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Sep 2015
    Backdraft suction you say? I’ll be go to h e. Double hockey sticks!
    Sena SM10 BT Dongle
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    Jun 2015
    Ritzville, Wa
    Peter, well that certainly sounds sciency so I'll go with that. Thanks.
    Greg Kamer
    Oct 2021
    TX
    We have been riding in Colorado and Wyoming for the past couple weeks. Each time I clean the windscreen, it looks like there are as many bugs inside as outside.
    2019 RTL
    2019 RTL , Blue
    Dec 2013
    BUGGA! And I tried SO HARD to avoid making it too 'sciency' and all!
    BTW, you'll probably be getting at least a few 'pre-smashed' bugs sucked in thru the vents in the lower section of the windscreen &/or up below the windscreen/above the cowl there too, and once they get caught up in all the turbulent air behind the screen, they can get smooshed onto the inside of it as well - after all, they come pre-smashed, so it doesn't take all that much effort to get them to stick!
    Didjya notice all those 'not very sciency' words & terms I used in that lot?? Words/terms like 'pre-smashed' & 'smooshed' etc??? Much less sciency than 'turbulent' & 'low pressure', aren't they??
    Apr 2019
    Florida Swamp
    They get smashed on the inside when you are in reverse, of course.
    2019 F3-S , Black & Silver
    Aug 2016
    South Wales UK
    Maybe try riding faster. If the bugs going in the same direction as you are flying faster, they will impact on the back of the screen.
    Jun 2015
    Ritzville, Wa
    BUGGA! Didjya notice all those 'not very sciency' words & terms I used in that lot?? Words/terms like 'pre-smashed' & 'smooshed' etc??? Much less sciency than 'turbulent' & 'low pressure', aren't they??
    The pre-smashed bugs don't bother me too much, but those post smashed bugs are a royal pain in the neck.
    Greg Kamer
    Very Active Member SLICE's Avatar
    Aug 2022
    manatee county Florida
    My wife learned last week on our trip not to wear Capri pants.. bugs hurt when hitting bare skin.
    Active Member Stache's Avatar
    Apr 2020
    Flatrock, NL, CA
    Clearly reversing too fast
    MWO (Ret'd) SJ Barnes
    ‘20 RTL Stone Grey
    named Britannia in honour of EE Doc Smith’s
    Grey Lensman’s ship.
    Farkles:
    Bestem Carplay
    canamsypderaccessories hitch and wiring harness,
    showchrome trunk rack,
    12v AND dual USB direct to battery in the frunk,
    dual USB switched in the blank console switch spot (parasites the power off the seat heater switch),
    frunk lid organizer,
    trunk organizer,
    showchrome rider backrest,
    ryder and passenger cup holders,
    ram mount for the iPad mini I use for GPS
    quadlock phone mount
    Nautilus horn
    Data blocker on the glove box USB
    Big Bike Parts highway pegs
    Spyderzone dash pouch
    Convex mirrors
    ‘20 Ryker 900 (my wife’s ryde)
    Farkles
    Slingmods fwd/rev ‘suicide shifter’
    frunk organizer
    dual horn
    Max mount
    Rear seat with tall back rest (not mounted)
    Ryder backrest (not mounted)
    Side bag
    Top bag
    top bag makes a good backrest. Will swap on the rear seat if she ever wants to 2up
    2020 RT Limited , Stone Gray
    Dec 2013
    And the face! And bare wrists or arms...
    In fact, like Slice says above, whenever/wherever they hit ANY bare skin!! Or even 'only thinly protected' skin!!
    Mar 2015
    forrest above Reno, Nv
    Lightbulb No back-o-the windshield bugs.
    For a long time on this site I mentioned that a VENTED windshield creates a larger "bubble" of still, high pressure are behind the windshield. It does....... really. I get no back-o-the windshield bugs and my wife has no turbulence. It's just simple aerodynamics.
    Lew L
    2014 RTS , Circuit Yellow
    Idaho
    Peter's comment about backwash is right on. If I ride through rain the backside of the windshield gets dirtier than the front side! And my two flags on the trunk are always flying forward, not backward!
    2014 Copper RTS
    Apr 2019
    Florida Swamp
    I never get smashed bugs on either side of my windshield.
    Idaho
    Quote Originally Posted by Gwolf View Post
    Are you saying Florida bugs or so tough they survive the collision and just walk around on your 'shield? Or is traffic so heavy you can't ride fast enough to cause them to be squashed when they do hit the 'shield?
    2014 Copper RTS
    Jul 2015
    Dorr, michigan
    Maybe he never rides???
    2020 RT Limited , Petrol Blue
    Apr 2019
    Florida Swamp
    The only windshield I have is hanging on the wall of the shop, where it has been for the last 20 years. It was on a 2001 Sporster when I bought it used. Took it off right after I bought the Sportster and it has been hanging on the shop wall ever since.
    I do get some bugs smahed on my face shield, but none on my windshield.
