Fix for the odd sized Pushpins in RT Black Panels!
There is one pushpin at the front inside of the black Tupperware on the Spyder RT. It goes vertically into a part of the frame just behind the A-arm. It is the same size and shape as the pushpins at the other end of the black panel behind the saddlebag. But it is SMALLER than the regular pushpins that cover the cycle. You can drive yourself nuts trying to get a regular pushpin into the too-small hole. Either the extreme front or extreme rear pushpins can benefit from replacing the plastic Phillips screws with real stainless steel sheet metal screws.
Reason: Expanded title to briefly state the reason for this thread! ;-)
Chip
2020 RTL
"Stella by Starlight"
UltraGard Full Cover, Front & Rear Cup Holders, Elka Stage 2 Rear Shock, TC & Dave Signal Button, Spyder Extras Sway Bar
Plastic pins are cheaper. Save a dollar on every Spyder built and it adds up.
I have found that 32 tpi screws best matche the threads in those rivets
2020 Spyder RT Limited; Deep Marsala/Chrome
Formosa AZ01 165/50/R16's on PPA Recluse wheels up front
General Altimax RT43 215/60/R15 on factory rear
Primary exhaust: RLS Cat delete w/ his baffle; secondary, custom built w/ Flowmaster HS2
Suspension: BajaRon swaybar (highly recommended!), M2 coil-overs, front & rear (also highly recomended!)
Extra LED lighting and misc. to suit my needs/wants
And better yet is replacing pushpins with rivet nuts so you can use machine screws. Like my flanged button-head hex socket machine screws that I've replaced all fasteners with. Easy to operate, easy to see, etc etc.
2014 Can-Am Spyder RT-S SE6 Freeway Commuter Pod
2016 Royal Enfield Classic 500 Fair-Weather Mountain Bike
Bert do you have a LINK for them ?????? .....Thanks ...Mike
And the installation tool.
https://www.spyderlovers.com/forums/...=1#post1658901
https://www.spyderlovers.com/forums/...=1#post1658979
https://www.spyderlovers.com/forums/...=1#post1659105
https://www.spyderlovers.com/forums/...=1#post1611674
First I made the decision to use stainless steel flanged button-head hex socket machine screws to replace the black steel Torx socket machine screws BRP used. Torx requires a fairly small angle of attack. Hex allows the use of ball-head wrenches with much wider angle of attack.
But I got addicted and started replacing u-clips with rivet nuts like this https://www.amazon.com/Stainless-Nut...dp/B08MCVCWYL/
After that success I went after pushpins. Due to the thin material a pre-bulb shank is required (just like drywall) https://www.amazon.com/uxcell-Multi-...dp/B0966ZKKKG/
A kit is nice https://www.amazon.com/Rivet-Profess...dp/B07T8YZY23/ and a two-hand tool is needed for 6mm and above. 5mm and below is best with a single-hand tool like this https://www.amazon.com/NEXTACK-Assor...dp/B09LV22WL7/ You will under- and over-tighten several rivnuts. Ratcheting tools help with fine-grain tightening control.
The extra length of the pre-bulb shank requires longer mandrels which I found at Summit Racing https://www.summitracing.com/search/...eumatic%20LM5M
That's all for tonight. Kinda tired from projects not going smoothly but I'll watch for questions.
That's awesome! My RT is gonna be a little heavier, but easier to work on very soon.
Anyone have a source for the stainless steel flanged button-head hex socket machine screws in SS and black... In the sizes and lengths needed for 2010/2019 RT's??? THANK YOU, larryd
Reason: ..ghts ;-)
I'm not sure there's REALLY a "black stainless steel"; I think it is a polymer coating on 18-8, 304 or 316. Check Amazon.
I would see if Mcmaster-Carr has them .... good luck .... Mike
Reason: Fixed quote display ;-)
Reason: ..nght ;-)
My local ACE hardware carries button head SS Allens in both metric and ASE.
"Love 'em all.... Let GOD sort 'em out!"
2021 RTL Dark Chalk Metallic with comfort seat
1978 GL1000 w/'75 engine show bike
1976 RD400c
Tags for this Thread
