Results 1 to 25 of 26
    Very Active Member SLICE's Avatar
    Aug 2022
    manatee county Florida
    Default Will this tire fit
    Quote Originally Posted by SLICE View Post
    Yes, it will fit the fronts of any Spyder with 15 inch wheels .... I have never heard of that brand, so why do you think it's a good choice ???? ....Mike
    Aug 2019
    southwest oHIo
    The FRONTS???
    That size (225/60-15) is better-suited for the REAR tire.
    Yes, it will probably fit, but your speedometer accuracy might be off a bit.
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    Quote Originally Posted by Steve W. View Post
    The FRONTS???
    Looking at its specs, most likely that tire'll bring your speedo/odo/trip meter's closer to 'accurate' than the OEM Tire sizes ever did!
    Yes, it will fit. Let us know how it works for you if you go this route. (Rear Tire)
    Aug 2022
    I first need a video of how to get the rear tire out of the 2022 RT-L.
    Can Am is completely Alien to me I'm use to Harleys.
    Mar 2013
    Marion, Arkansas
    I almost bought this same tire when I needed a rear tire several months ago, but I didn't. I had never heard of the brand plus the reviews talked about looks but not much preformance information. The tire I did go with was the Riken Raptor HR in the size of 215/60/15. I fellow Spyderlovers member suggested it. I'm happy with the tire so far.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    The FRONTS??? e.
    ... When I clicked on the Ad at the top of the page it said in large black type '''165/ 65 - 15 " .....Mike
    Active Member helton61's Avatar
    Jan 2023
    Virginia
    https://www.youtube.com/watch?v=7t6sLLfl6aM
    Mar 2021
    Arizona high country
    That's (General Altimax RT43 SL 225/60R-15) what I put on my 18 F3L and now my speedo is dead on with the GPS
    Active Member GFrog's Avatar
    Jan 2022
    Bedford, Nova Scotia
    If you find a video for the 2020+ RTs, please post the link.
    2022 Spyder Sea to Sky Mystery Blue
    2009 Suzuki Boulevard M50 SE
    Aug 2019
    southwest oHIo
    I have not looked closely at a '20+, but I'll bet that video will work. Yeah, the plastic is all different, but if you know which end of the screwdriver to pound on, I'll bet you can figure it out.
    HER ride:
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    Dec 2020
    Hartwell, Ga
    As a retired mechanic/shop manager/fleet manager, you don't pound on either end of a screwdriver.
    Jan 2021
    Oklahoma City
    See my post #27 in this thread, it contains some tips that I compiled from various other threads but don’t remember seeing them all together previously.
    https://www.spyderlovers.com/forums/...81#post1643681
    The 2020+ are not too different in regards to changing out a rear tire so videos from older models on this subject translate well to the 2020+ models.
    2021 Spyder RT Limited (Sea-To-Sky)
    2022 Ryker Rally
    Aug 2022
    Quote Originally Posted by Adventurer View Post
    Did the brake rotor have to come off to have the tire mounted.
    Jan 2021
    Oklahoma City
    No it didn’t need to come off.
    2022 Ryker Rally
    Aug 2019
    southwest oHIo
    If you are ever in this area, you are welcome to use my tools.
    HER ride:
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    Sep 2021
    NY or FL
    Spoilsport!
    Durham,Maine
    But it makes it easier to work around if you do!!! And getting the rotor back between the pads and getting everything lined up at the same time would be a pain!!
    2012 RTL , Pearl
    Jan 2021
    Oklahoma City
    Strangely enough I didn’t have any trouble. I did have to R&I the calipers, but I didn’t have to back the caliper pistons off to get the caliper back on the rotor, just made sure I was lined up with the rotor and not cockeyed at all, slipped right back on.
    2022 Ryker Rally
    Clinton, MS
    Depends on the tire mounting machine and the guy doing the mounting.
    2019 RTL Phoenix Orange
    Mattapoisett, Mass
    Forceum Hena 225/60R15 Fits my 2022 RT No problems. Rides better, more stable, Speedo is usually right on or 1 mph off. Haven't tried in the rain yet. 3,000 mi.
    Last edited by Peter Aawen; 07-23-2023 at 08:44 PM. Reason: Moved Post title into text - many only see Thread titles, and post titles mess with Searching! ;-)
    Aug 2022
    Quote Originally Posted by CBXBob View Post
    1650 right now and handles the rain perfectly.
    Last edited by Peter Aawen; 07-23-2023 at 08:45 PM. Reason: Fixed quote display ;-)
    Dec 2022
    Florida
    Which one, the Forceum or the Riken?
    Quote Originally Posted by mandytuning View Post
    Well, SLICE quoted CBX Bob ... so my guess is the Forceum ..... Mike
    Last edited by Peter Aawen; 07-23-2023 at 08:46 PM. Reason: Fixed quote display ;-)
