Results 1 to 16 of 16
    Feb 2012
    Spring City,Utah
    Default Garmin 550 not recognized by Garmin Express, but does charge - any ideas?
    I am going to post this here as I don't see anywhere else it might go. I bought a Garmin550 from a member here. When I tried to add it to my Garmin Express it does not want to recognize it. It turns on just fine and charges up. My cord is a Garmin factory cord and it works just fine on my 660. Anybody have any ideas? Also can the predictive script be turned off?
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Durham,Maine
    Try a new cord there may be a bent pin in the one you're using, or a bent pin in your GPS unit! I have one Garmin that acts up and will not boot up with one of my cords, the rest boot up fine. Try a different cord, bet it will work, doesn't have to be a cord from Garmin, just needs the right plugs on the end!
    2012 RTL , Pearl
    Feb 2012
    Spring City,Utah
    I'll give that a try
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Danbury Connecticut
    I'm assuming you have the latest version of Garmin Express (they seem to change it each week).
    If not, try an updated version.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Active Member PJveetwin's Avatar
    Oct 2022
    Peoples Republic of Calif. Upper Mojave Desert
    Are you running a PC or a Mac? Restarting your computer is a good start. The best source of information I have found is on ADV. https://www.advrider.com/f/forums/ma...navigation.37/
    2021 RT LT
    Nov 2019
    Central Oregon
    I have a 590 and have learned the cable makes a HUGE difference in Express recognizing the GPS. You'll need a cable designed for DATA; most any cable will charge just fine; not all carry data well.
    After many cable swaps, I found the one I use with my insulin pump, a data+charging cable, works with the Garmin.
    Best of luck.
    2015 ST Limited; Givi E52 Top Case; Baja Ron anti-sway bar; Cal Sci wind screen; Vredestein Quatracs (front)
    Dec 2015
    Oakley Utah
    You probably know this already Paul. There are USB charging cables that only charge, and there are USB data cables that also charge (slowly). Be sure you have the latter (although I would think your Garmin cable does both).
    2014 RTL Platinum
    Active Member ff73148's Avatar
    Jun 2018
    New Jersey
    At some point Garmin does not support the older Zumo's.
    Frank Ferrante
    2022 Can Am Spyder RT Limited Deep Marsala Metallic Dark
    2016 Moto Guzzi Eldorado
    Dec 2015
    Oakley Utah
    Quote Originally Posted by ff73148 View Post
    I still get support on my Zumo 450.
    2014 RTL Platinum
    Feb 2012
    Spring City,Utah
    My Nuvi 500 is still supported. The cable I am using is the same one I update my 660 with.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Dec 2015
    Oakley Utah
    Have you tried doing a factory reset on it?
    It's possible the device is faulty. Sometimes a factory reset will work and sometimes not. I also had a 660 I bought used and I never could get it to recognize the memory card in order to load bigger maps. I finally bought a used XT, which has been trouble-free.
    2014 RTL Platinum
    Feb 2012
    Spring City,Utah
    Thanks Pete. I am afraid that may be the case here. How do you do a reset?
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Dec 2015
    Oakley Utah
    I'll have to get back to you on that. I don't remember.
    2014 RTL Platinum
    Nov 2015
    Chardon, OH
    This notice from Garmin might apply here. Expand the list. The 550 is on the list. Perhaps Garmin Express is smart enough to know this and won't initiate an update. That's all I got.
    https://support.garmin.com/en-US/?fa...414&tab=topics
    Doug
    ”Freedom is not a loophole”
    Feb 2012
    Spring City,Utah
    Well that"'s a bummer. Now I have 2 boat anchors. A Nuvi 500 and this Zumo 550, which are both on the list. Glad my 660 still works. Just added a loop thru Wolf Creek Pass,Ut and Indian Canyon from Myrouteapp.
    Thanks for that list Snowbelt. I did not even know about that list.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Dec 2015
    Oakley Utah
    That explains it pretty well, I think. Very helpful. Thanks.
    2014 RTL Platinum
