OEM rear pads went 25K and front pads went 33K. I just turned 50k on EBCs and I'll have to check them to see what I've got left.
If you have 50K on the REAR .... better check them REAL SOON .... Mike
I checked my EBCs too today and ordered pads all around. Got 33,900 out of them. I too just dodged a bullet. Outside pad in left caliper was at 1 mm or just slightly less; inside pad somewhat more. I got 28,790 on second set of front OEM pads and 21,600 first OEM fronts.
They've 25k on EBCs, not 50k.
I just put a new set and a rotor on the rear of mine while I had the tire off for new rubber!!! Love them
Are these the correct pad replacement part numbers for my CAN-AM Spyder 1330 F3 SE6 2017
Rear
Part Number FA631HH
Front X 2
Part Number FA630HH
Rear
Part Number FA631
Front
Part Number FA630V
.... I don't have the package they came in .... But they are for the New Brembo Brake calipers , that came with the 1330 engine package.... check BajaRon's ( a site sponsor ) web site He lists all the ones He sells .... Mike
Sorry, I didn't make that very clear. OEM rear pads were changed out at 25k and ECB pads were installed. Now I have a total of 50k on the odometer so I've got 25K total now on the rear EBC pads. In addition, the second OEM brand tire was also replaced at 25K (outstanding millage for two crapendas how that happened???) so I'm due for a replacement soon on my first General Altimax and that also has 25k on it. EBC pads seem to be outlasting tires. At least the rear tire anyway. I may never have to replace the fronts.
OK that makes more sense .... If you got 25K from OEM Kenda's ...ON THE FRONT , that's not unusual for a well aligned non-defective Kenda. ..... others here report similar .... Mike
