What's the best music app to use in phone and listen to in a Sena?
My title pretty much says it all. I did an advanced search using "best music app on a phone" that turned up a lot of threads. None of the titles seemed to point me in the right direction so this thread is seeking out first-hand information on what others have used or are using to play music through a comm system. We have the Sena 10S units and feel like they are sufficient for our main purpose of rider to passenger communications.
Those who say " I can't" will always be right.
I mainly use Plex Amp to stream my music library from my home or download playlists if I will be out of coverage areas. I have also used Spotify and Sirius XM app which comes with my Sirius subscription for my car.
2021 Syder RT Limited
Due to riding a lot in areas that lose cell service I use downloaded Apple Music. Once in a while I’ll use SiriusXM or Dash Radio. Many use Spotify or Amazon music. All of which are streaming and only works with cell or WiFi.
In my opinion Pandora has the best playlists that don't repeat as often. And, you can listen ad free for $5 per month. Spotify also works well. I also have about 32gb of music on my phone if cell service is not available.
Peter Pan has struck again!
Spotify, and if no cell I have some music already downloaded on Spotify. Most apps work well at this point in time.
Reason: and ....
I use Spotify, Amazon Music or Sirius XM. I usually play albums or a motorcycle song list that I've previously downloaded onto the phone so I don't worry about no cell service.
My Mods:
Elka Stage 5 rear shock with spring preload adjust
Monster Stage 2 ECU
Pedal Commander
RLS cat delete
Baja Ron sway bar
Baker Air Wings upper and lower
Viking saddle bags
Third pegs
Vredestein tires front and rear
Mad Stad windshield
X-creen windshield deflector
Front and rear drive cam
Garmin Zumo XT
Heated gear wiring
Lamonster LED headlights
Lamonster LED foglights
Lamonster frame mount cupholder
BRP heated handgrips
Lamonster drivers backrest
BRP passenger backrest
Lidlock handlebar end helmet locks
Barkbusters Storm handguards
I use iHeartRadio. 99% of the time I have it on Smooth Jazz. I've never had any reception issues in the relatively local area where I travel.
Skip H.
'21 Can Am Spyder F3 S
'97 Honda Goldwing w/Hannigan Astro 2+2 sidecar
[img]
I really like Pandora and If you are getting the paid subscription you can download your play list and you don't have to worry about having wifi. I also like Sirius
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
Pandora does have an "offline" mode (with paid subscription) when cell service is unavailable. It stores on your phone your 3 most used stations for uninterrupted offline listening. I assume other streaming services have similar functions.
I use an MP3 player that bluetooths to the helmet speakers. I don't normally have the cell phone turned on when riding.
The little MP3 players will take a 32 gig or larger mini-SD chip. I have a collection of music I like. Most of it is 30 to 40 years old at least.
I use XM app on the iPhone.
Now here's a tip, go into setting and unlock your phone so you never need to use your pin or face to unlock it. That way, if you want to change station's you just need to tap the screen and the phone will open and you can change XM stations.... I strongly suggest you do all of this at a traffic light or stop sign. You don't want to be fiddling with your phone while driving. YYMV
Reason: pin of face... ;-)
